2002 Mac26x Detmar stiff steering fix
Posted: Thu Jun 23, 2011 9:27 am
Can't take credit for this fix as I found it on the forum board, however it probably saved me at least $300.00 in new steering parts.
1. Disassemble rack and pinion steering.
2. Remove rack and cable from boat
3.. Dip rack and cable; rack gear at top of pipe into 8' to10' of ABS piping capped and glued at one end fill with your choice of motor oil. ( I used 10/30 )
4.Let soak 1week or longer oil will travel up cable. ( I let mine soak 2 weeks )
After this treatment the steering regained the original operational performance and I saved the cost of buying a new steering system.
In future I will perform this procedure every 2 to 3 years based on steering performance.
Oil is cheaper than parts
