New to forum/Macs/sailing - have a couple questions
Posted: Sun May 29, 2011 11:48 pm
My dad's always wanted a sailboat, so for his retirement/birthday I decided to go halves on one. We scored a 1983 Venture 222 in nice condition and have been working the past couple weekends to get it ready for the summer. With that being said, I have a few questions...
The previous owner murdered the wiring on the inside. He added a nice fuse and switch panel and perko battery switch, which was wired in nicely, but then went bananas with the wiring around the cabin. There were wires ran every which way to a half dozen 12v outlets and a few lights, with everything installed by duct tape. Where was the original wiring ran? I see two wires being ran behind the starboard wood trim, back to the stern light... are there channels back there? I'm a bit hesitant to start tearing apart the inside that much.
The red/green light at the bow is missing. Does anyone carry a direct-fit replacement? I've checked West Marine and ebay, but have found none that mount the same way. The mount is welded vertically to the bow rail, and all the ones I've seen have the mounting holes on the bottom to be mounted horizontally.
Along the same lines, it seems I'm not getting power at the connections for that light. The lights are ran through the rail and into the cabin. If I tie some new wire together and start pulling, will I be able to string new wires through easy peasy? I'd hate to try it and have it jam up or something, and be stuck figuring out how to run new wire through there without any sort of assistance.
Does anyone have a bilge pump, and where is it mounted? There's water under the rear dinette seat from uncovered storage, as well as under the starboard cockpit seat that opens up, and in the little square space between the two areas. It seems as though the cabin floor doesn't drain into the rear? So I'm torn between mounting it in the little square space, or the larger space directly under the starboard seat.
My specialty is in the detailing. I'm obsessed with keeping my car nice and it carries over onto my boats (I also have a 20' bowrider). Here's a few before/after shots from getting rid of all the oxidation... pre-wax as I didn't finish until after dark and the boat's been under a tarp since then. The first shows post-work towards the rear and pre-work torwards the front. In the 2nd and 3rd pics, there's a little nick in the gelcoat that I'll repair sometime this week, and a big messy splotch of what looks like epoxy or silicone that I'm a little hesitant to remove
Thanks for any help. It's cool to see there's a fairly active community for these boats
