Questions....my first sailboat.
Posted: Sun May 01, 2011 10:18 am
Hey guys, I've read all i could find about the subject, but i still have a few questions.
1) When rebedding items that DO NOT go through cored areas, should i still use over sized drill and fill with epoxy? Or will a good backing plate and butyl tape suffice?
2) I've decided to use butyl tape for all my bedding needs, and alot of my bolt holes are small enough that the threads are actually screwing in. Shouldn't i enlarge these enough so that the bolts can be pushed straight through and then all the tightening on the nut only?
3) My winches are completely full of crud, after cleaning then, what type of grease should they be packed with?
4)I've removed all my windows to rebuild with new plexi and seals. I plan on painting the outside and inside trim, should i also clear coat non visible pieces like the inside lip that the butyl will be sealing against?
5) Where hardware attaches to non skid surfaces, should i grind and/or sand the surfaces flat before mounting?
Oh, and by the way, you can call me Joe.... I been lurking around in here for a week. I have learned ALOT! I have a 1977 Mac 25 ( a Venture...correct?). It is my first sailboat, I have never sailed. Oneida Lake, New York will be her home. If any of you are also on this lake, could you give me some idea of costs for a slip, both with and without power. Also, which marinas would you reccomend. My last boat was docked at Boats-A-Float in Bridgeport. I don't recall ever seeing a sailboat there. I like the marina alot, but it doesn't offer the quickest access to deep water. Is this why most sailboats seem to dock nearer the Eastern end of lake?
Any and all help will be greatly appreciated. Thanks in advance, Joe.
