Hello and a boom hardware question
Posted: Thu Apr 28, 2011 2:38 am
Hello!
First a big Thank You! to all on this board. I lurked here for over a year before I finally took the plunge and bought a 26X last summer and the board has been a great source of info.
It is my first boat, first time sailing, first time towing anything (250 miles to get her home) and although I only managed to get out several times last year it is already a bunch of fun. Even the last sail of the season, where an upper shroud snapped and I was left single-handedly lowering the mast for the first time in a choppy sea with the light failing, left me feeling happy that I had chosen the right boat for me as it was all quite straightforward.
I’ve now finished my first winter mini-overhaul – clean, anti-fouling, fixing leaks (I would never have found the locker leak without this board), new CB rope, etc. - and am just about to put her back on her mooring for the summer but I have a question about the boom hardware.
There are a couple of blocks, a cleat and a rope going inside the boom that I can’t find a use for and was wondering if anyone knows what they could be.
Hopefully there will be pictures below, but at the mast end there is one block on the left side and behind it a hole into the boom, and on the right side is a block with a cleat about 6 inches behind it. At the aft end is a block on the left just behind another hole into the boom, and on the right there is an eye. The rope (white with yellow flecks) in the pictures is attached as it was when I got it.
Any ideas?
Bruce
Any ideas?
Bruce
