Leaking Ballast Valve
Posted: Mon Dec 06, 2010 7:58 am
by icemen20
My ballast valve appears to be leaking and it is filling the ballast when I don't want it to. Has anyone replaced this item? Can you just get a new gasket or do you have to replace the entire valve structure?
Re: Leaking Ballast Valve
Posted: Mon Dec 06, 2010 8:59 am
Probably easier to just replace the whole valve. It must be pretty easy as many have done it.
See
http://macgregorsailors.com/forum/viewt ... f=9&t=1441
Another link.
Posted: Mon Dec 06, 2010 8:33 pm
by Divecoz
Yep Russ is correct ,its pretty easy and pretty cheap.. Well other than here today at 18 degrees F. :x
