jib question
john3357
Sailboat: Venture 2-24
jib question
Post by john3357 »
A newbie question. Laugh if you would like. I have a genoa sail on my venture 22 normally. When I bought the boat, it came with an extra jib. However, the sail has no grommets. The question is, how do I attach and raise the sail? What am I missing? Thanks for your patience.
Sumner
Re: jib question
Post by Sumner »
john3357 wrote:A newbie question. Laugh if you would like. I have a genoa sail on my venture 22 normally. When I bought the boat, it came with an extra jib. However, the sail has no grommets. The question is, how do I attach and raise the sail? What am I missing? Thanks for your patience.
You say 'grommets', do you mean hanks....
...........like in the picture above?
Is your genoa a furling sail that is on a furler on the forestay by any chance. If so then maybe the jib is designed to slide into the furler and replace the genoa.
Hard to tell without some picture or maybe more to go on.
Good luck and a year and a half ago I had no clue about any of the above :? ,
Sum
Our Trips to..
Our Mac Pages
Mac-Venture Links
jschrade
Re: jib question
Post by jschrade »
John,
Can you provide a picture of the jib? I suspect that there is a wire sewn into the luff but still there should be a grommet at the foot of the luff and the head of the luff that you would use to tension the luff of the jib. I suspect your sail may look something like this:
http://www.mariner-sails.com/assembly.asp?id=23174
Jim :macm:
Re: jib question
What Sumner said.
Maybe the jib is for a furling system and the genoa isn't.
Re: jib question
You would still need grommets at the head and tack....and the man did say no grommets....
sounds like the job was bought 'on sail'
(sorry - couldnt resist)
john3357
Re: jib question
Post by john3357 »
Sorry, there are grommets foot and head. The genoa has grommets all along it with hanks similar to Sumner's picture.
My question is how do I attach and raise the jib. Is it connected to the forestay all the way along or only at the foot and head?
Thank you for your help.
Sumner
Re: jib question
Post by Sumner »
Sounds like it is for a furler and slides up into that. You could probably put in grommets or have them put in and then get the hanks and then it would attach like your genoa,
Sum
Our Trips to...
Our Mac Pages
Mac-Venture Links
jschrade
Re: jib question
Post by jschrade »
john3357 wrote:Sorry, there are grommets foot and head. The genoa has grommets all along it with hanks similar to Sumner's picture.
This leaves two options:
1) There is a pocket in the luff that you can run a length of wire through to create the setup in the link I posted earlier. The wire becomes part of the forestay on many boats.
2) The luff has a "bolt rope" that will fit into a furler track.
Jim :macm:
