Wheel lug bolts for 26M trailer
Posted: Sat Jun 26, 2010 3:56 pm
by Phil M
I've spent an hour or two looking in previous posts for any information on the wheel bolts, or lug bolts, or wheel lugs, for my 2006 26M trailer. Two of the bolts sheared off (incorrect torque - my fault
) and now need to be replaced.
I took one of them to a local automotive supply store, and they looked throught their catalogue, but could not find a replacement.
Does anyone have any ideas of what type of vehicle would match the wheel bolts for a 26M trailer? Has anyone bought wheel bolts for a 26M trailer?
NOW I'm going to buy a torque wrench.
Phil M
Re: Wheel lug bolts for 26M trailer
Posted: Mon Jun 28, 2010 11:16 am
by Phil M
The only place in North America to buy wheel lugs or lug bolts or wheel studs for a 2006 Macgregor trailer is from Waymire Distribution 317-631-7551.
The part number for these press in wheel studs is 32498.
They only cost about $.75 each, but the shipping will be a bundle.
A cheap torque wrench is $20. Oh well. Live and learn.
Phil M
Posted: Sun Jul 04, 2010 6:02 am
by Hamin' X
Good info, Phil. Thanks for doing the legwork.
Posted: Sun Jul 04, 2010 7:24 am
by c130king
Hamin' X wrote:Good info, Phil. Thanks for doing the legwork.
Rich,
Don't you mean "Thanks for the doing the
lugwork"...
Posted: Sun Jul 04, 2010 7:27 am
by RichardB
I picked up a few recently from a local auto parts store, Bennett Auto Supply, in Lake Park Florida. They manually matched it as:
Part number: 610-192
Description: 1/2-20x2-1/32 Wh
# Manufacturer: ACDELCO
This is a Florida chain, but they are online at:
http://www.bennettauto.com/ and I was able to find that part in the online catalog with a part number search. Shows they are in stock and currently $3.49/ea. More than Waymire charges but thought I'd post just in case a second source is needed.....
Richard
Posted: Sun Jul 04, 2010 9:52 am
Don't you mean "Thanks for the doing the lugwork"...
Well struck, sir!!!
Posted: Sun Jul 04, 2010 10:33 am
by c130king
Stephen,
I am actually more proud of the fact that I beat
you to the punchline than I am of the punchline itself...
Sailing on König
(* T-Minus 9 days until I fly back to the U.S. *)
(* T-Minus 21 Days until I move König from Jacksonville, FL up to his new home at Ft. Belvoir, VA *)
Posted: Sun Jul 04, 2010 11:17 am
have a safe trip and a special thanks to your service on our countries 'Birthday'
Posted: Mon Jul 05, 2010 9:38 pm
by Phil M
Phil M wrote:The only place in North America to buy wheel lugs or lug bolts or wheel studs for a 2006 Macgregor trailer is from Waymire Distribution 317-631-7551.
Phil M
In fact, the shipping was $33 to Canada for 4 bolts less than $3 in cost.
And, they only shipped the bolts. I assumed they came with nuts. No!
I had to go out and buy some nuts to match.
So, using my torque wrench to take the old wheel nuts off, I measured my 'hand tight' bolts at around 50 lbs. of torque. They are supposed to be 85-95 lbs of torque. The wheel bearings are supposed to be 18-20 lbs of torque. I had them on at only 5 lbs when hand tightening.
The moral of the story is :
Use a torque wrench.
Phil M
Posted: Tue Jul 06, 2010 3:16 am
Setting wheel bearing by torque doesnt sound right to me. I think you should set this tension by taking up the play in the bearing only. Setting 5 ft-lbs of torque would also require a very low scale torque wrench too.
