Neutral bypass
Posted: Tue Jun 01, 2010 4:48 pm
I can't find a way to throttle-up my engine without engaging the gear. I have searched the site and only found one instance of my problem and his solution does not work in my case. Or, at least it does not appear to. When I try to pull out on the shift/throttle lever it will not budge. Have I got something hooked up wrong or something out of adjustment? My shifter looks likes this:
[quote="Doug W"]Great news and not so great news!!!
User error. My old '79 power boat had a throttle where you pull the whole throttle handle out and pushed forward to go forward and reverse to go backwards. It had a separate lever to pull out if you wanted to activate the neutral bypass to open up the throttle without being in gear. I forgot that you pulled UP to put the 26M into gear. I reverted to the old way and in thinking that I was pulling the lever out so that I would be in gear, the new fangled throttle was in neutral bypass
