Outboards in Salt Water Question.....
Posted: Sat May 15, 2010 8:03 am
Joe posted the following in the other thread, but I thought I would start a new thread so as to not mess up the other one.
The boat could be in the salt water for up to two months. Normally we pull the motor up as soon as we start sailing unless we forget to do so
. We also pull it up at night. In salt water would it be better to leave it down in the water at night and also if we were just sailing a little or sailing slowly where it wasn't hurting us that much?
I wonder if there would be less deposits/corrosion inside if it just stays wet and doesn't go through a dry/wet cycle. Or does it not dry out that much in a day on the inside anyway. I haven't seen anything posted about what is best in this respects.
Sum and Ruth
Our Trips to..
Our Mac Pages
Mac-Venture Links
I have a question along this line. We just ordered our new outboard yesterday from onlineoutboards, a 9.8 HP Tohatsu with electric start and the ultra long shaft. We will be in fresh water over the summer, but hope to be in Florida next fall.JoeVacs wrote:Also, don't forget, after running in salt water or brackish, you want to run the motor for at least 5 minutes in fresh water to rinse the cooling system. ( just in case you hadn't thought of that )
Sum and Ruth
Our Trips to..
Our Mac Pages
Mac-Venture Links
