Hi,
I know this has been discussed before, but I got a PM tonight regarding how to get the boat off the bunks, to paint the bottom of the hull. It always seems to be a topic of interest, so for what it’s worth, I thought I would post my reply.
The front of the boat is very light as it sits on the trailer. I used a small 2-ton floor jack and set it on the trailer tongue, under the boat, in front of the front bunk. I used a thin piece of wood between the jack and the hull to protect the hull from scratching. Jack the boat up a few inches.
Once you jack up the boat a little bit, you will be able to slide a beam between the hull and top of the trailer frame. This way, the boat is supported in case the jack slips. As you jack the boat higher and gain clearance between the trailer and the hull, slide the beam aft to maintain contact with the hull.
Because the floor jack is sitting on the trailer frame, it can’t roll to maintain it’s relative position under the boat, so at some point you’ll have to lower it, let the boat rest on the beam, and slide the jack back a little.
As I recall, after I raised it as far as I could with the small jack, I switched to a larger jack and raised it until the hull was only in contact with the rear-most bunks (making sure to keep the beam in a good position in case anything slipped). Once you get it in this position, you can sand and paint everything, except where it contacts the rear bunks and the support beam.
When I finished painting all that, I removed the support beam, lowered the boat onto the bunks and removed the floor jack.
Next, you need to get the boat clear of the rear bunks. To do this, I lowered the trailer-tongue-jack as far as it would go. I cut three supports out of firewood logs to fit under the rear of the hull. These supports don’t have to be a perfect fit, just cut them close, and use some shims to fit the curve of the hull.
Now, raise the front of the trailer using the trailer jack. As you raise the front, the rear of the trailer pivots down and the hull stays in place supported by the logs. Now you have access to paint where the boat sits on the rear bunks.
BR
Bottom Paint
- Rick Westlake
Re: Bottom Paint
Has anyone tried CopperCoat? It's a hard epoxy with "micro-spheres" of pure copper mixed into it. The company claims that it's good for 10 years! It's also a "smooth" non-ablating bottom paint, and being hard epoxy it should be A-OK for our "trailer yachts". It is expensive, though - I figure that enough to take care of a Mac 26-anything would be about $390 for the paint alone; but that's cheaper than (let's say) five two-year bottom jobs, isn't it?
as time goes by
Re: Bottom Paint
Hi ,I've applied coppercoat antifouling to our 26M and am extremely happy with the results.
we live in Tasmania and the boat is moored in salt water. we launched the boat in September last year and their is minimal fouling, absolutely no crustaceans just a brown slime which wipes off easily. i beached the boat at christmas time and scrubbed the bottom, which was easy. its now late march and the bottom still looks good.
Previously I would have to take the boat out of the water every 3 weeks at the latest to scrub and it was a chore.
The best thing is its hard so when you put her on the trailer it doesn't scratch off. Also its an epoxy base so it protects from osmosis.
Its easy to apply, just follow the directions.
happy sailing
as time goes by
happy sailing
as time goes by
