Bob26M wrote: ... I,m getting a 26m, 05 and am looking at 50-70 size engines. any info would be of a big help. I like the 50 but am thinking that I could run a 70 at less throttle at the same speed and maybe have longer eng. life ...
A little bit of voodoo and horse-puckey sometimes clouds this debate. Your focus is rather unique, and it calls to the foreground some of the issues I considered when choosing my Suzuki DF60. The easiest choice is to simply go with the largest motor within a particular series, but it may not be logical for your objectives. For example, one may choose a Suzuki 70 over its little brother the 60, spending extra for that choice. In fact, those two motors are physically identical, and their performance up to 5,000 rpms is identical also.
If you plan to operate only within the lower 80% power range (sounds like you are focused on long engine life), then there's absolutely no reason to buy the last 500 rpms of performance wherein the identical outboard produces its last 10 horsepower (from 60, up to 70hp). Suzuki programs the computer to clip the top rpms and hold the 60hp version in the lower rpm band. This was very clear on Suzuki's website when I bought my DF60 back in 1999. The power/torque curves for both motors were identical except for the dotted lines indicating max rpm range. (I think Mark did similarly in choosing the DF115 instead of the DF140, weights about the same).
So, the smaller motor of a sibling group could be the better choice (more cost effective) if your emphasis is mid-range performance. Unless you're expecting to run at WOT frequently, the 40 is likely a better choice than the 50, and the 60 a better choice than the 70, simply because they are usually 10 to 12 percent less expensive. (In reality though, the 40/50 are usually too small for a 26X, and I think that's even more true for the 26M).
Regardless of these horsepower issues, don't be misguided comparing solely by a weight difference. (Suzuki publishes the DF 70 @ 335#, the DF 60 @ 359# - the difference is liquids & installation stuff. All brands spin their weights like the politicos spin debates! Do you weigh yourself in your jockies, or fully dressed with shoes?) More significantly, engine weight may portend a larger, more powerful block (1300 versus 1000 cc), which can also deliver more amps, more torque, better gearing and quieter performance for longer life. Check this
Suzuki Marine page for comparative examples.
I strongly recommend you choose an outboard with a 14" prop, even if you suffer a weight penalty. I also recommend EFI and the lowest possible gearing (note that 2.42 is "lower gearing" than 2.30). I obviously favor Suzuki, but most importantly, choose a dealer that you trust to deliver a quality installation of your motor. Good luck on your new purchases.
