autopilot question
Paul S
autopilot question
Post by Paul S »
I figure someone on here might know.. our new boat came with an autopilot - raymarine ST7000. It doesn't seem to work well, the previous owner said it (the fluxgate) needed to be calibrated, he didn't use it and never calibrated it.
So I know I need to calibrate the fluxgate, but I have a question on the diplay unit itself. It is a pretty basic display - shows the rudder location, and a 'heading'. Now not sure if it is a silly question or not. But what is the heading showing? the actual compass heading (ie should change and match the boats compass) or the desired course? Right now it doesn't change as the boat moves. You can do a 360 swing and the display heading won't change at all. It could be the course heading you want, but the manual didn't say as such. It just said to hit 'auto' and it will keep the course you are on.
Maybe it will become clear once I calibrate the fluxgate.. but I was wondering more what the heading was supposed to show. I thouth it would display and match what the boat's compass was showing.
Any ideas?
Retcoastie
Re: autopilot question
Post by Retcoastie »
Calibration instructions are in the manual. If you don't have one the online is here: http://www.retrevo.com/d/ds/progress?do ... 52f2baf061
My Raymarine ST1000 shows a constant heading when the Autopilot has been activated (turn ON). In the STANDBY mode, it shows the current heading which changes with the compass. Perhaps yours is ON and not in STANDBY when you are looking.
Paul S
Post by Paul S »
Retcoastie wrote:Calibration instructions are in the manual. If you don't have one the online is here: http://www.retrevo.com/d/ds/progress?do ... 52f2baf061
Thanks
I have the cal instructions. Doesn't look too hard. The heading on my display doesn't change at all, in standby or auto. So something is wrong... I am sure the first step is to calibrate it.. Just got to find a calm day to do it
btw the link didn't work. I do have the paper manual, and you can get the manual from the raymarine website as well.
So basically the numbers should change. Mine doesn't at all in standby and auto.. Thanks for the confirmation
Hamin' X
Post by Hamin' X »
Heading is the actual direction that your boat is going. Bearing is where you want to go, or the direction of another object.
Paul S
Post by Paul S »
Hamin' X wrote:Heading is the actual direction that your boat is going. Bearing is where you want to go, or the direction of another object.
true.. but I wasnt sure what it was supposed to be telling me..as the display never changed.. :)
Post by Kelly Hanson East »
Simple paul - you are always heading where you are intending to go.....
:wink:
James V
Post by James V »
when I set my S1 Wheelpilot I found the book to be confusing from RayMarine. After finding out what all those terms meant and tweeked each one I was able to let the autopilot do the work. this is my first one and it took getting used to. After 6000 miles on it I am very glad that I installed and do recommend an autopilot for anybody who is going to make long passages.
Paul S
Post by Paul S »
Kelly Hanson East wrote:Simple paul - you are always heading where you are intending to go.....
:wink:
Is that something like a bullet goes where the gun is pointed, not where it is aimed :)
We are intending on going to Cuttyhunk this Thursday...May end up in Casco Bay with the way this autopilot is running!
Hamin' X
Post by Hamin' X »
Try pumping him up a little more. With more pressure, he may have better view. :wink:
SkiDeep2001
Post by SkiDeep2001 »
And DO NOT call him Shirley(surely) :P :wink: 8) Rob
Its a large building with sick people, but thats not important right now....
Hey - You're Kareem Abdul Jabbar!! No kid, you've got me confused with someone else...
Classic..... :D :D :D :D
craiglaforce
Post by craiglaforce »
Oh Stewardess, I speak Jive
http://www.youtube.com/watch?v=3TDRMlwXUZw&NR=1
http://www.youtube.com/watch?v=6fZwMcoDVJM
Chump don't want da help, chump don't get the help! Jive ass dude ain't got no brains anyhow. (I actually use this quote often)
One of the best movies of all time.
Rick Westlake
Post by Rick Westlake »
SkiDeep2001 wrote:And DO NOT call him Shirley(surely) :P :wink: 8) Rob
Wasn't even planning to call my autopilot Shirley.
It's customary in aviation circles to call the autopilot "George" ...
But in honor of this great classic flick I may name my new X-5 SmartPilot "Otto". :P :P :P
Paul S
Post by Paul S »
Just an update - fixed it
The NMEA output of the fluxgate was connected to the output of the autopilot. Moving the wires to the INPUT fixed it!
Just got to play with it a bit!
Paul
Hamin' X
Post by Hamin' X »
Glad you got your bearings. I figured you'd get headed in the right direction. 8)
