Use the mapcal to scan for new charts, When I did this, it found two charts that were uncalibrated and it refused to add them. After mapcaling them, everything thing works fine. Open the list of charts in SeaClear and select the one you want to start with. On any border of the the chart chart being viewed, double click and the next chart will appear where you left off, but only if it is available.
Here is my recommendation for an easy way to get all the charts into the Seaclear\CHARTS folder and the way that I did it.
Downloading Charts
Make a sub folder in the SeaClear\charts folder and call it whatever you want. I named mine "Downloaded".
Go to
Noaa's Raster Navigational Charts and after agreeing to the terms, select the charts that you want to download. I prefer to use the graphical mode.
To select the charts that you want, zoom in to the area that you want by using the pan tool (grab and drag) and clicking on the zoom in, or zoom out tool. Do not use the + - Zoom bar, it will mess you up, at least it does me.
There are two ways to select charts for adding to your cart. I prefer the outline method. Using the selection mode tool, left click and drag an outline around the charts that you want. Don't worry if other charts that you don't want are highlighted.
The charts that you selected are outlined in dark blue. If you know for sure that you already have one of them, you can deselect the one that you don't want by hovering near the border, until it turns green. Now hold down the Ctrl key and click on the chart that you don't want.
When you have the charts that you want (The more you download at once, the less work involved) selected, add them to your cart on the left side of your screen.
Now place your order.
When a list of your charts appears, click on Order Selections. depending on the number of charts you are ordering and how busy their server is, this can take several minutes.
Now click download, then save it to your downloads folder. (Remember, this is a government site, so don't expect it to be fast, or work every time.
Putting Charts Into SeaClear
Now the neat part. I am using Windows XP, so your procedure may differ, depending upon the OS that you are using.
After the download is finished and saved, open the folder and unzip (extract) the file where it is.
Open Downloaded folder and click on search, then search all files and folders. Search the downloaded folder and all of it's sub folders for "*.kap" without the quotes. This will produce a list of all of your raster charts in this folder.
Now highlight all of the files and right-click and copy.
Click on Folders in the top bar.
In the left-hand panel, navigate to your charts folder (C:\Program Files\Seaclear\charts.
Now right-click in the charts folder, then click Paste. If it asks you to overwrite a file, click yes, as you will be getting the latest updated file.
Using MapCal
Mapcal is located in the Seaclear folder and you may not have a shortcut to it. The name of the file is MapCal_2.exe.
Open MapCal and click on Tools => Autoload List => Scan for New Charts.
It will give you the number of new charts that it finds and notify you of problem charts, if any.
Your done.
Just run SeaClear II and chose the chart that you want to start with.
