How is the stern light attached?
Posted: Fri Feb 06, 2009 10:16 am
by MadMacX
Hi Guys,
I want to replace the lamp cord that runs back to the stern light, but for the life of me, I cannot figure out how the light is attached to the boat. I looked through the plug access hole and can see no mechanical fasteners, so I guess it is held in place with 5200, or some such stuff. I hate to pry on it, if it is in fact, attached with screws. Anybody got any ideas?
Pat
Re: How is the stern light attached?
Posted: Fri Feb 06, 2009 10:23 am
by Hamin' X
Have you removed the lens cover to check for screws from that end?
Posted: Fri Feb 06, 2009 10:27 am
by March
On mine, it's just two screws into the fiberglass. People have been grabbing it when using the ladder to get on board (there's a handle there, too, but who cares. It's too obvious) It came off last year. I patched up with MarineTex and sealed it in place with silicone. Drilled new holes and fixed in place good as new.
Posted: Fri Feb 06, 2009 10:38 am
by MadMacX
Hamin' X wrote:Have you removed the lens cover to check for screws from that end?
That's the first thing I did. No screws.
March wrote:On mine, it's just two screws into the fiberglass. People have been grabbing it when using the ladder to get on board (there's a handle there, too, but who cares. It's too obvious) It came off last year. I patched up with MarineTex and sealed it in place with silicone. Drilled new holes and fixed in place good as new.
I was afraid someone would say that. I see the two holes for screws, but it looks like there is some type of bedding compound in the holes.
NOT a happy camper!
Pat
Posted: Fri Feb 06, 2009 11:04 am
by Hamin' X
I hate it when that happens.
Re: How IS the stern light attached?
Posted: Fri Feb 06, 2009 11:13 am
by Night Sailor
I just this a.m. discoverd the same puzzle on my '98 X. I want to move up to the top of my stern arch so it won't be covered by the enclosure I'm making. One machine screw hold the lens cover on, but inside there is no visible means of fastening from the top. I gently pried up the edge of the plastic as far as I dared and there is no sigh of a bedding compound. From my access port on the outside of the coaming directly beneath it, I could not feel anything like a fasterner from underneath it. It appears as thought the bulb socket base might extend into the deck but I did not feel anything there.
I sure hope someone lets us know what gives before we have to destroy the old one... and maybe find a big hole to fill instead of just screw holes.
Posted: Fri Feb 06, 2009 11:19 am
by Hamin' X
May if someone fires off an email to
Blue Water Yachts, they will have some info?
Posted: Fri Feb 06, 2009 11:26 am
by MadMacX
OK, I got it. It was held down with some type of black bedding compound, actually more like black GLUE. Once I got it out I found several holes under the light fixture. Looks like the PO had a little problem drilling holes. The light I have is an Aqua Signal light so I'm not sure it is original. It looks like it was supposed to have a rubber gasket under the light, but none is present.
Well, I'm going to clip the wires and put in some decent boat cable. What a complete waste of time just to replace the cheesy wire that Roger put in these boats.
Next up, the interior lights. Not sure I'm going to attempt the bow light, that looks like a real project to figure out where those wires run.
Anyway, thanks guys,
Pat
Posted: Fri Feb 06, 2009 12:37 pm
by Captain Steve
Pat, On my 98 the wires to the bow light are easily found under the lip of the liner, port side forward of the galley. You can feel them when you pull the lip inward. I tapped into it there to put separate lights on cabin sides
Posted: Fri Feb 06, 2009 1:26 pm
by March
I thought you meant how the pole is attached to the Fiberglass hull. I never took the lens apart. Sorry, I goofed
Posted: Fri Feb 06, 2009 7:23 pm
by Night Sailor
I found the same element on my X which has the original AquaSignal light in the original location. No bedding compound or gasket, but very tough glue. I used a steel leader wire to saw back and forth from all sides to lossen it without damaging the light.
Posted: Sat Feb 07, 2009 6:00 am
by MadMacX
Night Sailor wrote:I found the same element on my X which has the original AquaSignal light in the original location. No bedding compound or gasket, but very tough glue. I used a steel leader wire to saw back and forth from all sides to lossen it without damaging the light.
That's too funny. I did the same thing to "slice" thru whatever was holding it down.
Pat
Posted: Sat Feb 07, 2009 6:11 pm
by Rick Westlake
The original bow and stern lights on Beija-Flor, my
, were AquaSignal 20's ... the stern light wasn't working, the wiring was shorted out, and I had the
of a time getting a cable to it! Finally put in a Beckson 4" inspection hatch just below it, to have something that would seal up. (At least that thing looked as if it might belong there!) After that, the light worked ... okay.
Roger must like those AquaSignal 20 lights; they're on my
Bossa Nova, too. I mean to replace them with LED lights, unless Dr. LED comes out with a peanut LED for that series of lights. I just hope there will be enough leader beneath the old stern light, because I am not afraid to drill a bigger hole this time!
