AM/FM Radio Antenna
Posted: Mon Jan 26, 2009 8:28 am
by MSN-Travelers
I am about to install a stereo system in the cabin. West Marine has two internal model AM/FM antennas listed (1 store brand and a Jensen apmlified model).
Can you tell me what you have used as an AM/FM antenna? Internal, external, mast mounted or ???
Paul
Re: AM/FM Radio Antenna
Posted: Mon Jan 26, 2009 8:45 am
by Paul S
I used an antenna on our powerboat that looked just like a piece of wire - it worked quite well. fiberglass boats have no metal like a car to shield it. It is cheap and easy, and works well. If I ever put a fm radio in, I will probably go with that
Paul
Posted: Mon Jan 26, 2009 9:32 am
by kmclemore
Easy solution:
Take your existing VHF aerial and use it to also get your FM/AM reception. One antenna, no hassle. Works a treat.
Pacific Aerials SBS VHF/AM/FM Band Splitter
Posted: Mon Jan 26, 2009 10:03 am
by Hardcrab
We have good results with an "automobile" powered-type FM antenna bought at a car parts store.
About 8 bucks or so.
It's much like those wire "T" antennas that come with stereo receivers, but with a small amplifier inline.
It gets energized with the radio's ON switch via a provided 12v output wire.
It's mounted behind the small mirror at the daggerboard trunk, in the same general area as my radio.
AM reception isn't great, but that's not an issue for us.
Posted: Mon Jan 26, 2009 10:37 am
by extreem
When I installed the stereo in my :macx: , I used one of those flexible automobile type antennas and just pushed it up through the overhead bracing. It was simple to do, just remove one of the larger hole plugs and push it in. It is snug enough to not allow movement once it is in.
Gary
Posted: Mon Jan 26, 2009 12:13 pm
by David Mellon
I use a handheld VHF so I opted for a small stereo antenna from Waste Marine. I ran the wire through the same boot as the motor control cables and right up the gallows.
Posted: Mon Jan 26, 2009 1:15 pm
by Bill at BOATS 4 SAIL
kmclemore wrote:Easy solution:
Like Kevin said. Use your VHF antenna for your AM,FM.8-track.
I've used the one made by Shakespeare on page 127 of the West Marine catalog (Model 247413). Maybe someone can do a link. I don't know how to do that.
Posted: Mon Jan 26, 2009 2:32 pm
by David Mellon
Hey Bill...Where can I buy an 8-track?
Posted: Mon Jan 26, 2009 3:00 pm
by Boblee
Crikey I have had two of those splitters but neither was any good, one was US frequencies and the aussie one did SFA so just ran a piece of 4mm wire and strapped it around the lifeline and it works great.
Will have to fix it one day but can't seem to find one that will work inside, maybe I should makle the effort.
Bob
Posted: Mon Jan 26, 2009 3:03 pm
by dennisneal
I followed Hardcrab's advice and installed a device which is similar to this one:
http://www.sourcingmap.com/universal-ca ... 27883.html
Mine works great!
Posted: Mon Jan 26, 2009 5:51 pm
by Kelly Hanson East
I had one of the Shakespeare antennas on a long cruise, but on the Twelfth Night it gave out...
Posted: Mon Jan 26, 2009 6:15 pm
by March
Hope it wasn't much ado about nothing. My radio too connects to a Shakespeare antenna conveniently attached to the stanchion. Height--about two feet above upper deck level. Range--who knows.
I noticed last summer when I forgot to attach the antenna that my radio was still accessing the local weather station. Seems that the antenna did not make all that much difference.
I'm sure things change considerably when it comes to open seas
Posted: Mon Jan 26, 2009 6:57 pm
Bill at BOATS 4 SAIL wrote: I've used the one made by Shakespeare on page 127 of the West Marine catalog (Model 247413). Maybe someone can do a link. I don't know how to do that.
I used the Shakespeare splitter and it works really well. My antenna is on top of the mast and that gives me great reception with am/fm. Some would say it also degrades VHF, but with the antenna 30' up there, it's still better than most who's is 8' above the waterline. With VHF, height matters. My am/fm comes in great.
Posted: Mon Jan 26, 2009 8:31 pm
by Graham Carr
West Marine link for the "Band splitter"
