Page 1 of 3
Adding slugs to the factory main sail.
Posted: Thu May 29, 2008 8:25 pm
by Obelix
To be able to raise and lower the main from the cockpit, I want to add slugs to the luff on my 2008
How many slugs are needed and at what distance from each other should they be mounted?
As always, thank you for your insights.
Posted: Fri May 30, 2008 2:02 pm
by James V
There is a lot of threads on this via Search -
http://macgregorsailors.com/phpBB/searc ... de=results
Unless you know what you are doing it might be better to take the main to a sail loft (somebody who works on sails). The botton is the hardest as you will need to put in a rope system to get the sail down far enough. Check the mods on this.
Posted: Fri May 30, 2008 6:58 pm
by deja_vu
Just finished adding them using the KH kit. The instructions are't quite right, ifyou space them anywhere close to 12" you'll end up running out of slugs a little after 13'. Anyway spaced 18" apart per some of the other posts you'll use all 15 in the kit. Took a whopping 25 minutes to do. I took some pictures so when I get a chance I'll do write up. Very easy to do.
Posted: Fri May 30, 2008 7:33 pm
by Obelix
That was the reason why I asked, I got the KH kit but the instructions made no sense at all. Either you run out of slugs after 13' and need additional parts or the recommended spacing had to be wrong. I'm still thinking what to do on the bottom, since the rope-channel is cut of for about 1 foot on the bottom on 2008 masts.
Thank you everyone that chimed in.
Jurgen
Posted: Sat May 31, 2008 9:30 am
by c130king
Can one of you guys list what comes in that $39 kit from KHM? I will need one for my new sail that I got from KHE.
If I have some of the kit already (like a sail slug stopper) I wonder if it would be cheaper to order the other pieces seperately from a marine supply place (life Defender).
sail slugs - Reef point
Posted: Sat May 31, 2008 10:12 am
by live2shift
My 26M came with them in all holes except the reef point, do you guys usually put one in there?
Posted: Sat May 31, 2008 10:22 am
by c130king
What holes are you talking about?
Posted: Sat May 31, 2008 11:03 am
by parrothead
Some sail slug kits employ grommets [creating holes in the leading edge of the sail], some do not.
No slide is installed at the reef point, since it gets slipped over the reefing hook at the side of the gooseneck, becoming the tack of the reefed sail.
Posted: Sat May 31, 2008 12:31 pm
by Obelix
C130 King,
The kit includes 15 slugs, 15 shakles, 15 screws and a sail-stop.
Jurgen
Posted: Sat May 31, 2008 12:32 pm
by c130king
Thanks.
I just ordered 20 3/8" slugs and 20 5/8" shackles from sailrite. Total was $25 plus shipping.
Probably don't need 20 but will have a few spares.
I will forego the grommets and just use the screws through the material behind the bolt rope.
Spares
Posted: Sat May 31, 2008 1:08 pm
by pokerrick1
The spares you will absolutely eventually need - - - you will break some plastic shackels.
Guys; if he forgoes the grommets won't the sail rip apart at that edge - - - will it last
Rick
Posted: Sat May 31, 2008 1:11 pm
by c130king
My current sail does not have grommets...at least I am pretty sure it doesn't. Haven't seen it in nearly a year but I think I would remember if it had that many grommets.
And I read some other posts (search on "sail slugs") and seems like several others went that route as well.
Posted: Sat May 31, 2008 10:15 pm
by deja_vu
The screw ones have a post that you place right off the bolt rope, all the tension will then end up on the bolt rope and not the screw, I'll try to post the pics I took tomorrow.
20 pieces screwed in
Posted: Sun Jun 01, 2008 6:00 pm
by TAW02
I have an M and I screwed 20 of those suckers (shakles) into my sail boltrope area. Hope I didn't overdue.
Big T
PS, I put one every 16" and like I said, I used 'em all. All 20 that I bought!
Oiy Veh!
Posted: Mon Jun 02, 2008 3:01 pm
by tangentair
Bill from Boats4sail rigged mine as part of his upgrade package and they worked fine all last year. They are 24 inches between until just above the reef point then the next is 24 inches from the reef point to the base. The tip has 2 closely spaced. Pictures follow:
The sail looks like this:
the Tip has two closely spaced at 5 and 9 inches from tip
the rest are 24 inches on center
down to just above the reefong point
starts again 24 inches below the reef point
and is 27 inches to the final one
to the base of the sail.
And yes Jim he uses grommets.
