Engine trouble?? Mac 26M
Posted: Tue Jun 29, 2004 6:45 am
I have looked at a lot of the threads here and not quite found my answer. I have lots of experience with engines (gas and diesel) and other auxiliary gear, but not so much with tiny little outboards. I also have never kept a boat in a slip for extended periods. So, here is my question:
I have a brand new (got in April) Mac 26M with a Honda BF50. I have ablative (read: not very smooth) bottom paint on the boat and keep it in a slip.
From day 1, I never got more than about 17 knots (19.5 mph) out of the boat, and it would drop to about 16 knots with ballast full. I figured I was not getting the advertised 20-22 mph due to the bottom paint slowing it down.
The "stock" prop that came with the motor is a 3-blade aluminum and is marked as 11.75x10.
Most of the time I motor just to get out of the basin, but I do usually open her up to w.o.t. for a minute or two after a period of running at 5-7 knots, just to "blow out" the carbon. Generally I don't pay attention to the speed though, or I haven't been...
The other day I actually had to motor for several miles due to the wind dying, and found that my max speed is now 12 knots (ballast full)! The motor is still developing 5500 rpm w.o.t. (red line at 6000) and the prop is pristine. I had the ballast full, the DB down about 6 inches (for tracking) and the rudders fully up. No substantial load in the boat and only myself (200 lbs.) on board. About 20 gallons of fuel in the tanks.
So, any ideas what is going on? If I have a clogged fuel filter or something, the engine would not still reach 5500 rpm would it? It's been in the water (salt) for 2 months and it doesn't "look" like there is much, if any, scum on the bottom, but could this little layer of scum be enough to cost 5 knots?
AndyS
AndyS
