Reefing question
Posted: Sun Jun 27, 2004 8:48 pm
As a new owner of a 26M, I have a question regarding reefing of the mainsail. The luff of the mainsail is held in the rear of the groove in the mast by a series of slugs that slide upwardly within the groove. My question is: Where should the slugs go when you lower the main to one of the reefing points (three in my case)? In the M, there is a widened area or slot in the lower portion of the groove in the rear of the mast, just above the gooseneck, through which the slugs are inserted when the sail is being set and raised. There is also a removable "keeper" or stop member that the dealer fastened just above the slot, after the sail was raised, to keep the sail from sliding back down and keep the slugs from falling out (rearwardly) through the widened slot area. -
The problem is that when I lower the mainsail to bring one of the front reefing cringles or grommets down to be fastned onto the reefing hook near the gooseneck, the stop member (mentioned above) prevents them from sliding down past the top of the widened slot area. In other words, I can't get the luff of the sail down far enough to attach the selected reefing grommet or cringle to the reefing hook. As a compromise, I had to tie a rather long Cunningham line through the reefing grommet to hold the sail down while the sail was reefed. This didn't work well, since the slugs "bunched up" above the stop member and the resulting reefed tack was a foot or so above the level of the boom, and the foot of the sail wasn't aligned well. - I hope I have explained the problem clearly enough, but if not, let me know and I'll try again.
My question is: is the recommended solution to remove the keeper and pull the lower slugs down and out of the widened slot area so that the reefing cringle can be pulled down far enough to reach the reefing hook? If so, is it necessary to tie the lower slugs together to keep them from flying about?
Thanks for any suggestions or advice.
