Page 7 of 7
Posted: Fri Sep 07, 2007 2:16 pm
by R Rae
From Beene:
Don't you mean...
"FLOAT PLAN"
Could be "flight plan" if your airfoils are working at 110%
Posted: Fri Sep 07, 2007 5:56 pm
I said when I am sailing.... do you run the motor when sailing
Edgartown Rules.......
Posted: Sat Sep 08, 2007 6:30 am
by beene
Only time I had to run the motor while sailing was when I was trying to keep up to Highlander sailing his tri-headsail
config in 35 kt winds
Just kidn'
Posted: Sun Sep 09, 2007 8:29 pm
by Highlander
Posted: Mon Sep 10, 2007 8:57 am
by beene
You mean...... knot
Posted: Fri Sep 21, 2007 12:35 pm
by RHC
Can anyone post a diagram of a typical jackline system for the Mac 26X? (describing the matls used for lines and hardware). People who single hand on regular basis, what's your trigger for hooking up your harness? Is it anytime you're on deck? If waves are more than 3ft?
Thanks
Posted: Fri Sep 21, 2007 4:55 pm
by johnnyonspot
Jackline? Hooking up? What's all that about. I don't hook in or tie off when singlehanding, but then again I am rarely if ever out in 3 foot waves, and there are no oceans near me. I always wear a PFD however.
Re:
Posted: Sun Aug 16, 2015 4:19 am
maddmike wrote:Sitting on Zeno's Arrow Maho Bay St. John some years back, VHF on, scanner on:
Call comes over channel 14(as I recall?)
"Moorings base Tortola, this is Moorings boat 'Sunrider', Virgin Gorda, we require imediate assistance".
"Sunrider, This is Moorings base what is your situation?"
"We are in need of an anchor, unable to anchor for the night and it's starting to get dark".
"Sunrider, Moorings base, your have three anchors on board, what is the problem?"
"Yes Moorings base, we did have 3 anchors, but this is our fourth night out".
Old thread warning. I was searching mikes posts for some info on oars and found this classic, which I have repeated often.
Re: Re:
Posted: Sun Aug 16, 2015 4:49 am
by dlandersson
While one can argue that single-handing is more dangerous than not (no one else on board to help if there's an accident), I think a major plus of the Macgregor (at least when slipped) is the ease of single-handing. It's pretty easy (about 30 minutes) to prep and go sailing.
My X is out far more often than most of the other boats. Some never seem to leave their slip.
to
Catigale wrote:maddmike wrote:Sitting on Zeno's Arrow Maho Bay St. John some years back, VHF on, scanner on:
