Page 7 of 21
Re: Yet Another Galley Mod
Posted: Fri Aug 21, 2020 8:21 am
by Jimmyt
Posted: Fri Aug 21, 2020 11:26 am
by Jimmyt
Well, had a few final adjustments to make it work, but it's all mounted and works exactly like I wanted.
Even after mocking it up, I wound up with the trash can interfering with the tilt out by about 1/8". So, I had to break the glue joints on two of the locating strips and move the trash can back a tad. The other issue was just a matter of counter sinking the screws that mount the pivot rod plates to the cabinet frame. I have the door gaps tight, and the screw heads were interfering with the door edge. Not too bad (if you don't count the eight hours it took me to wrap my head around it and execute
Posted: Fri Aug 21, 2020 2:13 pm
by Starscream
Wow. The craftmanship!
Posted: Fri Aug 21, 2020 3:27 pm
by NiceAft
Jimmy,
You deserve a hearty congrats for the workmanship.
I still have concerns about the weight. Have you launched your Mac yet with the mod installed? I’d be interested to read your observations on how level she floats.
Posted: Fri Aug 21, 2020 3:30 pm
by Jimmyt
Starscream wrote: ↑Fri Aug 21, 2020 2:13 pm
Thanks! I'm no cabinet maker, but it's coming along pretty well.
Posted: Fri Aug 21, 2020 3:42 pm
by Jimmyt
NiceAft wrote: ↑Fri Aug 21, 2020 3:27 pm
Jimmy,
Thanks Ray!
You're watching me build it real time. I still have a bit to do before installing it.
BOAT tells me it's just going to slide off the trailer and roll over!
We'll see. I am going to put the water tank on the opposite side to help balance it out, but I think it's no worse than two (maybe three) lead acid deep cycle batteries. I haven't weighed it yet. All of our scales went in the dumpster after our fire and we never replaced them. I'll have to figure out how to weigh it or go get a scale... A big Yeti full of ice and cold stores for a week probably weighs more than my galley.
I'm sure it won't heel more than 15 or 20 degrees!
No more pics today. After finishing the tilt out, I spent the rest of the day sanding and varnishing. Not much to look at yet.
Posted: Fri Aug 21, 2020 4:33 pm
by NiceAft
Maybe your next mod will be installing dual ballast tanks and an electric sump pump to move the ballast in accordance to the heel?
Posted: Sat Aug 22, 2020 5:57 am
Jimmyt wrote: ↑Fri Aug 21, 2020 3:30 pm
You ARE now a cabinet maker. Looks great!
Posted: Sat Aug 22, 2020 8:58 am
by Jimmyt
Russ wrote: ↑Sat Aug 22, 2020 5:57 am
[quote=Jimmyt post_id=344250 time=<a href="tel:1598049054">1598049054</a> user_id=16979]
[/quote]
Thanks Russ!
Posted: Sat Aug 22, 2020 5:04 pm
by Jimmyt
Posted: Sun Aug 23, 2020 2:59 pm
by Jimmyt
Posted: Mon Aug 24, 2020 8:46 pm
by Jimmyt
Well, made a tool run this morning to replace my RO sander. Spent most of the day sanding and varnishing; and watching it dry
Got the second coat on the cabinet. Need at least one more coat on the cabinet and drawer fronts.
Spent some time this evening fine tuning the trash can door. Drawers got dry enough for me to install the soft-close hardware and the tilt out storage - hopefully for the last time. Slow going from here on.
Posted: Tue Aug 25, 2020 7:17 am
by K9Kampers
Looks great! Nice craftsmanship! Looking forward to watching the install video!
Posted: Tue Aug 25, 2020 8:27 am
by Jimmyt
K9Kampers wrote: ↑Tue Aug 25, 2020 7:17 am
Thanks! I guess I should video the install - the doc will want to know how I injured myself...
Posted: Tue Aug 25, 2020 3:41 pm
by Jimmyt
