Here's my thoughts on sail rig.
The only unstayed rig that will allow a headsail is the sprit rig, because as the snotter is tightened, and the sprit is under greater tension, it not only produces a flatter sail shape, better for performance, but it also induces an aft bend in the mast which in turn tensions a forward shroud, which allows you to run the jib.
I have seen results of where they used the same boat, and changed the rig, lateen,sprit, balanced lug, gaff and sloop.
The sprit was by far the best performer on all points of sail, except for sailing to windward,and only then was it just beaten by the sloop,cos it has the higher aspect sails.
The only downside of the sprit, is the reefing procedure, as the rig has to be scandalized, to reduce sail area, and on a bigger boat, that sprit in a good blow, can play havoc for the reefer.
If I knew how to post pics, I could post my preliminary sketches of a boat I am seriously considering building,
twin master, in a schooner type configuration, but with unstayed masts.
fore sail, a boom less sprit, and jib, the aft mast probably a boomed gaff, both mast sockets to run right down to the keel, help keep it watertight, and robust!!
with an open backed pilot house, so that the wheel steering is undercover, but access to the cockpit is still easy and quick, and the option of a canvas and clear plastic house aft bulkhead.
a larger uncluttered cockpit for fishing, and entertaining etc,
still to sleep six, 8.5' wide, and somewhere around 30' long, or slightly less.
easily and legally trailer able, water ballast etc
better galley, bigger head, with the
type head layout ,but with a shower,
either twin bilge boards or still the daggerboard/centerboard configuration,
removeable tiller for sailing.
Just sketches right now, trying to find a good naval architect or designer to do the final drawings, as I would like to start building soon!!!
I love my new Mac,and am more than happy with the sailing performance, but want something more user friendly, and want something just a tad bigger-but isn't that always the case, if I had a 70' boat, I would probably want a 72' boat.
Oh we'll, alls good for now
