Hi StarScream!
Thanks!
Weโve not had many opportunities to carry that many aboard.
We pretty much limit ourselves when out on long term cruising trips given we are somewhat loaded up with stuff & supplies anyway.
We also have a bit of a list to our Port side due to weight distribution. About 3+ degrees
Our dual batteries and A/C unit are both on that side and aft of the galley which is driving the issue.
From an existing layout perspective this works for us but when loading and storing we definitely make the effort to place stuff on the Starboard side to try an balance things out. If we ever get to adding fresh water or holding tanks or additional battery capacity the Starboard side is gonna be the target zone.
We had originally intended to place the A/C unit on the Starboard side but the old design compromises of what you want vs. what you can get vs. what/where you can fit pushed us over to the Port side.
We try and compensate by burning of the fuel from the Port tank first and situating passengers to Starboard when appropriate to level things out.
A dropping swing keel could be a real problem!
๐ซฃ
That lift line arrangement does invite chaffing.
Iโve checked it before launching each season but when one is on the water for several months it is something that is on oneโs mind.
Especially when in our early days when we were first getting acquainted with Over Easy.
I check the keel lift line after several trips only to find it had chaffed about a 1/3 of the way through the line opposite the knot.
We replaced the line and tried to protect it some with a coating of liquid line end faying stuff.
It looks like it has helped but will probably have to replace the line again when we haul out at the end of season or if/when we have opportunity sooner ( our hurricane plan is to haul out rather than get beaten against the slip should we have to contend with that prospect
๐ซฃ).
Speaking of hurricane prospects weโre hopping the current mess headed to Florida fizzles out once it hits shore.
Watching the forecasts closely!
Reminds me
..I need to get our house portable generator interface wired in todayโฆ best be getting busy with that while the weather is still somewhat clear. Whatโs the point of having a generator if you can only use it with extension cords
Best Regards,
Over Easy
