Page 4 of 4
Posted: Tue Feb 13, 2007 9:46 am
by K9Kampers
Or, along John's idea, having the ball bungies at the ready to thread the grommet & lock the ball. I think it might be faster than tieing / untieing a pre hung reef line? Plus the ball wouldn't be wearing on the sail all the time.
Posted: Tue Feb 13, 2007 10:00 am
by eric3a
Posted: Tue Feb 13, 2007 10:24 am
by K9Kampers
I can see your point. Thanks Eric.
Posted: Tue Feb 13, 2007 11:07 am
by Terry
eric3a wrote:Bungies are just not strong enough. You need to keep the sail shape and lines are the best way to do that. Use low strecth lines.
I use a half shoe-lace knot (don't know the English maritime term for it) to make sure I can undo when needed.
Eric
Eric:
Wouldn't low stretch line put extra strain on the grommets and rip them out of the sail? One might think that bungee cord would give a little thereby keeping grommet rips to a minimum. I realize most of the load is at the tack & clew but even when the sail is not reefed the load is more evenly dispersed along the bolt rope in the boom, but when reefed there is more load concentrated at the grommets. Are loose footed sails only attached at the tack & clew or are there a few sliders along the foot of the sail fed into the boom?
Posted: Tue Feb 13, 2007 11:46 am
by delevi
My sailmaker advised thin sail ties, feeding them through the reef diamonds and tying off the excess sail when reefed.
Posted: Tue Feb 13, 2007 12:03 pm
by Scott
Keep in mind that a reefed sail works like a loose footed main. The ties basically hold the rolled up excess sail. They are not intended to bear the weight of a full sail as the boltrope in the foot. The stresses are picked up in the tack and clew and sailshape is controlled along the foot by the outhaul.
Posted: Tue Feb 13, 2007 1:47 pm
by eric3a
Posted: Tue Feb 13, 2007 10:23 pm
by delevi
No matter how hard I pull on the outhaul, within the reefing lines the sail isn't flat enough to my liking.
Check this out
http://macgregorsailors.com/phpBB/viewt ... 6874#76874
Click on the outhaul/reefing link.
Leon
Posted: Wed Feb 14, 2007 1:12 am
by Highlander
Posted: Wed Feb 14, 2007 6:22 am
by bobmonroe
For mainsail furling I put three stainless eyestraps popriveted on one side of the boom, on each end and one in center, on the opposite side put two
stainless hooks, halfway between the eyestraps. Use bungie cord thru the
eyestraps, tie off both ends, experiment with the tension you need to
pull over the sail to the hooks. Leave the bungie on the boom.
Posted: Wed Feb 14, 2007 7:25 am
by KayakDan
I set up a reefing system by installing 3 jam cleats on one side of the boom in line with the reefing cringles. I ran lines through the sails,knotted on both sides so the won't come out.
To set the reef,bring the sail down,grab the reef lines,pull it under the boom,and jam the lines up into the cleats.
