Page 4 of 5
Posted: Thu Apr 06, 2006 6:25 pm
by baldbaby2000
I like the hose idea. I put some closed cell foam under it for tomorrow. Maybe I'll combine the 2. I'm not really too worried about the board. The bottom is about 2" thick fiberglass; above that is solid lead. After lowering it on the bar I checked for side-to-side movement and it seems negligible so I don't think I'll do anything special. If the boat and trailer move independently, I think the board will slide on the crossmember without causing too much stress on the trunk. My biggest concern would be a failure of the bar on the trailer so I'll keep the keel line slightly taut.
After owning 2 Mac 25's which have 650 lb keels that rest on the trailer, my 26M's 90 lbs seems rather tame. The Mac 25 keel was pretty sloppy in the trunk and I'm sure it bounced around much more than my 26M daggerboard will. The current owner of the Mac 25 is a very good friend of mine and after 20 years there is no noticable trunk wear.
Posted: Tue Apr 11, 2006 12:31 pm
by delevi
180 lb db
Posted: Thu Apr 13, 2006 6:20 am
by Newell
delevi,
Looks like Ida Sailor has done a good job. Board appears great and looks deceptively lightweight. I quess it will be shipped freight.
I'm convinced the X needs more surface area exposed to the water, when I see how much larger the M board is in comparison.
Newell
Currently on Ocracoke Island NC
180 lb db
Posted: Thu Apr 13, 2006 6:22 am
by Newell
delevi,
Newell
Re: 180 lb db
Posted: Thu Apr 13, 2006 7:20 am
by Divecoz
Newell wrote:delevi,
Newell
I find the above very interesting as I . . .don't recall that coming up on this board before.
So I ask just how much smaller is the swing keel on the X than the board on the M ?
Posted: Thu Apr 13, 2006 10:53 am
Just as an add-on, I measured the M daggerboard area as about 4 sq. ft and the X as 2.5 sq ft.
There goes the blue hull advantage.
I measured this by porting Rogers CAD output on his website into an integration program I wrote in COBOL with nested assembly, and checked it by measuring on my screen with a ruler, and got the same result.
Your area may vary.
Posted: Thu Apr 13, 2006 11:10 am
by DLT
Boy, I sure hope it gets warm enough for Stephen to go sailing soon...
X centerboard improvements?
Posted: Thu Apr 13, 2006 12:16 pm
by Richard O'Brien
I suppose this belongs in a new thread?
I met a sailor last night who has a San Juan 21. He said that they came with vinyl tabs that cover the slot when centerboard is lowered, and that they have lasted for over 20 years. I wonder if something like that might help the X lower it's resistance? If I get to see his boat (he's in the same dry storage lot) I'll check it out?
Posted: Thu Apr 13, 2006 12:25 pm
by NautiMoments
Did you measure how many square feet are really in the water. I believe 12-16" stay in the trunk. May make those blue hulled
s faster. Those Xs have a built in water brake (drag) system called the swing keel trunk.
At least the
ers have a good knowledge at what the
stern looks like when they are racing.
Posted: Thu Apr 13, 2006 12:35 pm
by Scott
Yeah , ok whatever. How much stays in the boat on an M??
Engineers..............................Oh yeah, Lazer beam ray gun scientists too........
Posted: Thu Apr 13, 2006 12:51 pm
by Richard O'Brien
Posted: Thu Apr 13, 2006 1:50 pm
by Chip Hindes
At least the Xers have a good knowledge at what the M stern looks like when they are racing.
Actually, never seen one. Is it similar to that of the X?
I know the only M I've ever been out with has a pretty good idea what mine looks like. BTW, it looks the same when when the Tohatsu's cookin' (except smaller; perspective, you know) as it does when it's sailing.
Probably why the Ms need the extra windows in front, so they can better see who they're chasin'
Posted: Thu Apr 13, 2006 2:00 pm
by DLT
Chip Hindes wrote:Probably why the Ms need the extra windows in front, so they can better see who they're chasin'
Nice dig... And we certainly had that coming given the earlier inference...
But, the M doesn't have extra windows in the front, only on the side... I guess that's so we can get a better look at you
while we're passing you, it all happens soo quick you see....
Posted: Thu Apr 13, 2006 2:02 pm
by Chip Hindes
You mean those double stacked windows in the front are fake?
Posted: Thu Apr 13, 2006 2:05 pm
by DLT
Yeah, there are only two front facing windows...
