Page 4 of 4
Re: etec issue
Posted: Tue Mar 14, 2017 2:48 pm
by BOAT
With 34 gallons you will be able to go almost twice as far - it not quite doubles your fuel capacity - it's another 40% - that's a lot.
http://shop.bwyachts.com/product-p/4011-1m0.htm
Re: etec issue
Posted: Tue Mar 14, 2017 4:12 pm
by Starscream
About 4mpg at full throttle with an etec 90. Give or take.
I cruise with two 9 gal tanks, plus another 6 gal in a portable can under the captain's seat. That could get me over 60 miles before I need to go to the portable tank and throttle back. 60 miles at full throttle is too close to work for my taste. After an hour at wot it's time to be somewhere.
Actually that big tank that Boat found won't work for the X. I still lift and shove my tanks into the alcoves under the seats. I have to take the caps off to get them in there, and be careful not to spill. I usually only put about 6 gal in the tank to make them possible to carry on board.
Re: etec issue
Posted: Tue Mar 14, 2017 6:47 pm
by Highlander
@ $380.00 us a fuel tank I,ll stick with my 4 x 6 1/2 Gal portable marine fuel tanks as most of the time I usually only fill 2 at a time for local sailing , all 4 for cruising so if the wind & or weather decides not to co-operate N/P I got a 75HP Merc 4 stroke that,ll kick-ass if needed or great for extended cruising & tides & or currents become less of an Issue if u r running a little behind schedule & have the HP to run against them if u don,t mind burning up the extra fuel , the weather , tides & currents still have to be given respect as the only advantage a big eng. will give u if caught out in big swells is having the HP to get u up & over the big swells as u will not be running any more than hull speed @ best !
If I was going on an extended cruise where I needed that kinda fuel range it,s a lot cheaper just to buy a couple of 25ltr portable fuel cans & use my portable electric fuel transfer pump to transfer the fuel , this is not something u r going to be doing on a reg basis so why tie -up all that usable space all the time
Just Sayin Thats All
https://youtu.be/I8JGckmN5n0
Re: etec issue
Posted: Wed Mar 15, 2017 7:57 am
by npsrangerchuck
bahama bound wrote:I repowered with a brand new 90 etec ,I do not believe anything serious is wrong with the motor ! Would love to get it out of my shed I would take 1650.00 for it .new motor did the same thing ended up being those cheap Attwood universal connectors.
What year is your 75 etec? How many hours do you have on it?
Re: etec issue
Posted: Wed Mar 15, 2017 3:05 pm
by bahama bound
Came new on the boat in 2009 ? Reportedly had 86 hours when I bought the boat and I put about 10 on it
Re: etec issue
Posted: Wed Apr 26, 2017 2:31 pm
by profitt2
Just saw this thread... I have had an e-tech 90 on my 26m for about 7 1/2 years. Runs great - only problems were occasional water in tank... additive helped. Very fast and smooth. Lots of hours on it. Hope this helps.
Re: etec issue
Posted: Wed Apr 26, 2017 3:00 pm
by BOAT
Hey! 7.5 years in a MAC and you have only posted 11 times! What's up with that? Don't you like us? :cry:
Re: etec issue
Posted: Sat Apr 29, 2017 12:21 am
by Gazmn
BOAT wrote:Hey! 7.5 years in a MAC and you have only posted 11 times! What's up with that? Don't you like us? :cry:
:D :D
Apparently, he's busy Enjoying his Mac! :D :D
It's nothin' Pers'nal - It's Business 8)
PS: Try Star Tron Enzyme Fuel Treatment Profitt :wink:
