mastreb wrote:BOAT wrote:I wish i were as smart as Victor - there are SO many gadgets i would like to have that do not exist right now for the MAC -
electric solenoid valve on the forward ballast tank vent: http://www.zorotools.com/g/00062230/k-G2477474
I got the solenoid valve. I can't blow air in on one side, but I can blow air in on the other side. On the side where I can't blow air in when i put voltage to it I can blow air through it. I geuess it can only seal air going in one direction, but not the other direction. I assume it must be a floating valve that slams over to the other side when energized.
I need to think about this one:
If I mount it one way, it can't blow air out of the ballast until I hit the electric and then it will open up and let air pass, but it CAN suck air INTO the ballast when it's OFF or ON in that configuration.
If I mount it the other way it will not let air INTO the tank unless I hit the electric, but it will let air (or water) OUT of the tank when it's ON or OFF.
I don't know if that's good or not - I need to think about it before I install it because I'm not the sharpest knife in the drawer so it's going to take me a while to figure out.
I guess my fear is that water will leak out when I heel over real hard. (?) I'm also not sure that it lets the air pass fast enough - I'm going to go back to that website and see if they have a 1 inch or even 1-/12 inch - I think the air flow when filling the tank is important. (I think?)
The prices on the valves are great! (thanks Matt!) so I don't care if I have to buy three or four of them to get to the right one.
