Re: This isn't about MacGregors... but you're my friends,
Posted: Sun Dec 23, 2012 9:48 pm
Mastreb – All good questions. Without going too far into a technical realm that is waayyy beyond the scope of a forum post….
The conditions that influence the corrosion of submerged metals are much more complex than just the lack of oxygen. Low temperature, lack of strong currents, organic biofilm presence, contact with other galvanic series metals, encrusting minerals, pH, alkalinity, dissolved solids, sulfur presence, high ambient pressure, are just a few that come to mind.
In reference to plain distilled water being considered corrosive…
While in theory distilled water is pH neutral, in reality it absorbs carbon dioxide from air which lowers its pH (ie. makes it acidic, since, unlike “plain” water, it has no pH buffering capacity). Ultimately, it becomes a weak solution of carbonic acid which, you guessed it, is corroding. Anyone can confirm this for themselves with litmus paper, or pool pH indicators.
Since the 70’s I’ve been distilling my own (but not hootch
) for drinking and cooking, so I’m somewhat familiar with it, and this is a well-known property of distilled water.
Also, where metals are placed in contact with distilled water, both elemental metal, and metallic ions will begin to migrate into it, down a concentration gradient, because there are no ions already in it (not unlike the osmosis that happens in FRP boat hulls). In fresh water that already is nearly saturated with minerals and ions this migration rate will be lower than with distilled water. Just two reasons (there are others) why distilled is classified by chemists as being corrosive.
Corrosion is an electrochemical process (an anode-cathode redox reaction), so the localized flow of electrical current within the pit will be a dominant factor in corrosion when oxygen is not. As a high school chemistry refresher- oxidation is defined as a loss of electrons, or the gain of an H+ ion, neither of which necessarily involve an oxygen molecule itself.
The corrosion pitting reaction in stainless steel does not reach completion and stop when oxygen is used up and thus “cut off” to it. Quite the opposite- it continues; repeated observation of corroded stainless steel parts in the field confirms this.
I’ve had little experience with saltwater-exposed boats (we stay away from them!), it’s pretty well all been with freshwater. I have many times over the years seen stainless steel bolts that have been severely pitted (cut through) from being buried in freshwater-saturated plywood backup pads for deck fittings, where oxygen has been cut off.
I’m doubtful that the points of corrosion on the fittings you mention are sufficiently cut off from oxygen for oxygen starvation to play a dominantant role in pit corrosion. If the fittings are stainless steel attached to aluminum with fasteners, then the dominant source is more likely galvanic corrosion occurring between dissimilar metals that are located at different levels on the “electrochemical series” hierarchy.
Corrosion obviously happens at a higher rate in salt water conditions, but it is certainly an issue in fresh water conditions in those areas where oxygen has been excluded. So excluding oxygen from the joints and crevices, or anywhere in stainless steel fittings is to be avoided wherever possible in both fresh and salt water environments.
Hope this helps. – Brian.
