Hi All!
Tuesday was a great day! Lots of fun!
Wednesday was also a great day to celebrate as well!
The sun was warm, the skies were clear and the water calm!
Starting out at low tide was interesting to see all the oyster beds and sandbars exposed.
There were several dolphin family groups to watch this afternoon!
The calves are getting bigger but still stick close to their Moms. The Dads are right there as well too! Very nice!
Lunch out on the boat is always a treat!
Did a little preliminary sketching to see what might be the best location to add a fixed location searchlight(s).
Here is what the 7” searchlight might impact forward visibility when up on plane.
I lined up on another vessel to portray some of my forward visibility concerns.
Her the circle is roughly to scale for a 7” searchlight mounted just under the bow rail.
It really has the possibility of hiding potential obstacles.
It’s not much better if I were to mount it above the bow Nav lights either…and would complicate things if/when we ever get to install a bow anchor roller and drum winch. It’s sorta why when we mounted the base for the existing movable remote control searchlight it was placed on the lid of the anchor rope locker.
Here is an alternative that would utilize a pair of 4” square searchlights to the bow rail uprights.
While the reach of these search lights is about 900 ft is about half of the 7” searchlight’s 1800 ft there is much less forward view obstruction to contend with.
One of the advantages of either fixed location means that te lighting would be always available rather than having to dig out and mount the remote control one we currently use. The other is the fixed locations out in front ahead of any boat structure eliminates the backscatter lighting that reflects with the current setup. This has been found to be somewhat problematic for one’s night vision particularly on moonless or overcast nights.
While the longer range projection of the 7” searchlight is of benefit I’m not keen on the amount of obstruction incurred.
The pair of smaller 4” searchlights definitely can take advantage of the existing obstruction of the bow rail uprights to have less impact.
If we really need the extended reach the current remote control search light does have that but at the ‘expense’ of the backscatter.
The shorter 900 ft reach of the 4” searchlights basically translates into slower nighttime transit speeds which isn’t all that bad a trade off for better night vision and less forward visibility obstruction all the time.
So while the 7” searchlight is pretty neat function wise and there was a substantial savings when combined with the ‘free’ $70 wiring harness it looks like I’m gonna go ahead and return them in exchange for the pair of 4” units and cobble together a custom wiring harness. It’s one of those things where a really nice product just might not be as good as an adequate product in the greater scheme of things.
The motivation is with all the waterways we have here to explore we have been more frequently finding ourselves out well after sunset, especially in the early and later parts of the boating season, than we had originally anticipated when we got started. It’s one of those evolutionary adaptive things. Another up side of the pair of 4” searchlights is a bit of redundancy that the single 7” searchlight doesn’t afford.
Best Regards,
Over Easy
