Page 3 of 3
Posted: Thu Nov 08, 2007 12:58 pm
by Dimitri-2000X-Tampa
I used to do that dance, and now I think its downright dangerous (especially with the boat on the hard). Much easier to unhook the forward lifelines on both sides. That way you don't have to put the spreaders under the lifelines when in trailering position. The little bit of lifeline slack is enough for the spreaders to rest on them without any strain.
Posted: Thu Nov 08, 2007 2:05 pm
by waternwaves
i am kind of partial to the idea of a collapsing tube in tube type solution..... with spring pins, (set them while on deck, shorten 8 inches or so each for travel)
inspired by all of Johns innovative deck and mast solutions....
with the vibration cycling the mast gets I suspect all non rigid methods will wear, and then the lifeline connections seems preferrable..
Posted: Thu Nov 08, 2007 3:18 pm
by bscott
Newell---how much did you cut-off? I have been seriously thinking about this but NO GUTS. I can see lots of down wind sailing advantage to the shorter spreaders as well.
bENT SPREADER TUBE
Posted: Fri Nov 09, 2007 11:27 am
by RICH RUYACK
Hello Guys! newbie here, love the site. You guys are a wealth of information. I broke my spreader tube taking down the mast last week. Question? where or how do I get a new one. I know thats its 1" od alum. but would rather buy one then fabricate one myself.
Posted: Fri Nov 09, 2007 11:58 am
by Paul S
blue water yachts
http://www.bwyachts.com sell spreaders
Paul
Spreaders
Posted: Fri Nov 09, 2007 12:18 pm
by RICH RUYACK
Thanks! I'll check them out.
Rich R. N.Y.
Posted: Fri Nov 09, 2007 6:53 pm
by Captain Steve
www.boatbimini.com(an advertiser on this site) sells a set that has a smaller O.D. tube inside the aluminum one for extra strength. I got a pair and they are great.
Posted: Sat Nov 10, 2007 4:23 am
Thats interesting Steve, is the inner tube also aluminum or is it PVC? One thing I would be careful of is that if you make the spreaders too strong and then you snag them hard enough (enough to bend the original spreaders) makes me wonder if you might damage your mast at the spreader sockets. The spreader sockets are strong SS but the mast that it is attached to is very weak aluminum (think beer can). Of course, I guess the sockets are through bolted so that is a lot stronger than just attached to the outside of the mast. Anyway, maybe something to think about.
Posted: Sat Nov 10, 2007 2:23 pm
by USAF M26X sailor
I use the pins like the one in Scott's pix to hold the rudders up while towing. You have to use the U shaped version to get around the bracket. I still tie the rudders up but this is a quick/cheap back up.
Posted: Sun Nov 11, 2007 3:17 pm
by ALX357
bscott.
in answer to your question about spreader length reduction, here is a recent thread.
http://macgregorsailors.com/phpBB/viewt ... 6099#96099
Posted: Sun Nov 11, 2007 5:39 pm
by bscott
Good stuff, thanks
