Stoves... which fuel do you prefer?
What kind of fuel do you use?
Poll ended at Mon Apr 19, 2004 12:55 pm
Propane
6
24%
Butane
4
16%
White Gas (Coleman fuel)
1
4%
Alcohol
12
48%
Other (Please specify)
2
8%
Total votes: 25
Duane Dunn, Allegro
Post by Duane Dunn, Allegro »
We have the rubber seals somewhere for our's, but haven't used them for a couple years. We never have had an evaporation problem. I fill the containers and there is still fuel there months later with just the metal flapper slid closed. Over our 3-1/2 week trip last summer we never ran out, and we used the stove for a lot longer than 4.5 hours. We have a 2 burner origo and unlike most use it for cooking and washing for 3 meals a day. The BBQ out back get far less use.
jeffz
Dickinson grill
Post by jeffz »
Newbee with 26m on order from BWY
They sell magma grills but seeing the reviews sounds like they are not the best. Dickinson has an attractive kettle Sea-B-Q. Any experience? :macm:
Québec 1
Post by Québec 1 »
Okay,
I live in Canada and there is nothing that I can see called denatured alcohol in this country for my Origo stove. :evil:
Do I use fondue fuel from the grocery store, camping stove fuel from Crappy Tire or Methal hydrate from Home depot, or ethanol from somewhere or What?:?
I looked this up for 1 hour ,except obviously at the right place, and can only find conflicting definitions.:?:
A simple answer with the name of a easily available product will suffice. 8)
Thank you gentlemen!
Q1
David Mellon
Post by David Mellon »
I use alchohol from the paint department at Home Despot, any hardware store should carry it. I prefer the plastic jug because it stows better and will never rust.
cuisto
Post by cuisto »
Q1
I use the methyl hydrate...can get it at my marina or across the strre at the home hardware for 1/2 the $$$
Québec 1
Post by Québec 1 »
Thank you gentlemen.
Methyl hydrate it will be as I have not seen anything called alcohol at a hardware store around here. I will get it in the plastic jug !
Q1
dennisneal
Post by dennisneal »
I installed a one-burner Origo drop-in stove in our 2006 26M. It was easy to do. But, frankly, I prefer plugging in the shore power cable and using a microwave oven. For cabin heat, I use a small, electric fan/heater. Both work just fine.
Québec 1
Post by Québec 1 »
dennisneal wrote:I installed a one-burner Origo drop-in stove in our 2006 26M. It was easy to do. But, frankly, I prefer plugging in the shore power cable and using a microwave oven. For cabin heat, I use a small, electric fan/heater. Both work just fine.
My origo came with the boat but I do the same as you when shore power is availble. My small fan heater works just great and I plan on getting a microwave, but can't find one that is small enough to hide someplace. Also will be getting a generator next week at Canadian Tire on sale for 279$
LINK
which I will be able to hook up to the shore power plug for complete boat power and battery charging when on the hook! Its just a small generator but for the price and the portability I can run my interior lights and one appliance at the time which I can live with.
Q1
 ! kmclemore:
Shortened link
Alex
Post by Alex »
Only Honda generator !!!!
Don't buy any junk from Can tire !!!!
Québec 1
Post by Québec 1 »
Alex wrote:Only Honda generator !!!!
A portable generator with a four year guarantee for 279$ is the only junk I can afford. If it does not work to my liking I can sell it for 199$ on the local ebay and take the loss. If it last 4 years it will have cost me 75$ a year to have a portable generator .....sounds good to me!
If you can get me a Honda for 350$ I'll take it!
Q1
James V
Post by James V »
There is a 2 cycle in the states as well for that price. As long as you can handle the variable voltage and a little extra noise you should be fine. for an additional $ 500 (around $ 750 USD total) you could get a Honda or Yahama. $ 500 for an off brand.
Let us know how it works.
dennisneal
Quebec1,
I purchased a 700 watt, GE microwave, (model# JES0736), at Wal Mart for about $60.00 +/-. Its big enough to hold a full-sized dinner plate on the turntable, yet small enough to easily stow while underway.
This particular model has a capacity of 0.7 cu. ft. and measures 18" wide X 10" high X 12" deep.
Works great!
Dennis
Québec 1
Post by Québec 1 »
James V wrote:There is a 2 cycle in the states as well for that price. As long as you can handle the variable voltage and a little extra noise you should be fine. for an additional $ 500 (around $ 750 USD total) you could get a Honda or Yahama. $ 500 for an off brand.
The Canadian tire generator is a 4 stroke and just 3 points noisier than the Honda ,also has variable speed and stuff
Q1
DaveB
Re: Stoves... which fuel do you prefer?
Post by DaveB »
Kevin, I have used all types in the past 40 yrs. Best was Kerosene oderless and had to buy the burners thru a swiss company to convert from Alchol but 2 gals lasted over a year cruiseing thru the carribean.
It is just as hot as Propane but you need a small bottle of achole to prime.
Thats for living aboard, I use Butane now as it fits in the stove, quick release and can get at least 3-4 days meals on it. I don't worry about leakage as the tank is so small it wouldn't build to much is the lower cavities in the bildge, I keep 2 on board as spares.
My main cooking I do at the companion way cockpit with propane and store these 1 lb cannisters next to the 6 gal fuel tank.
This Colman is great and easy storage with easy cleanup.
http://www.campersland.com/col9940-755.html
2 llb can will last you 10 days cooking on it every day.
kmclemore wrote:When I got my 26 :macx: it didn't have the original stove - it was long since replaced by a fridge and a formica countertop. I'm now setting this boat up for a week's outing this summer and I'm trying to decide which sort of fuel to use and shich stove to buy. Now, I don't want to start some sort of religious disagreement over this... I just want to get some advice from all you learned souls!
What stove and fuel do you use? Do you like it, and what safety factors did you consider?
I know that Alcohol burns cooler but has safety on its side. Some folks swear by the Butane stoves but I'm concerned about the availablity of the cannisters when I get to port. Propane is another choice, too.
Any advice? Thanks!
-Kevin McLemore
DaveB
Post by DaveB »
I like my 1200 watt Gen. for $129. ya it's 2 cycle but noise isn't that bad and fits in front of the Mac.X motor perfect. Small compac with 4 rubber legs and not top heavy like the Hondas.
