Page 3 of 3
Posted: Fri May 27, 2005 9:46 am
There are two problems, and perhaps no fool-proof solutions for either problem, but there are some partial solutions.
1. Fabricate a "stop device" that can stall the skipper-less craft.
A nearly perfect solution for a "sailing" auto-stop would be to re-pilot directly upwind, approximating a heel-to. It requires a real-time wind indicator linked to the pilot, and an intelligent device that can direct the pilot to that heading. The "stop device" that signals an emergency piilot heading could easily kill the outboard too, if running.
An imperfect approximation is to hold the helm hard-over, but I doubt there's any direct way to force an active autopilot to hold the helm on-stop? I guess an approximation will vary with behaviors of various autopilots ... change pilot's heading by 90+ degrees, then kill the pilot's power line, leaving (and holding) the helm hard-over ... ??
It seems to me that this stop-device, and its controlling behaviors, is the crux of the problem.
2. Activate the stop-device when Skip takes the dive.
Once a quality stop-device has been designed, the wireless electronic anklet, water-triggered, is the obvious perfect solution. Where money's no object, the technologists will be eager to fill this vacuum.
A lanyard is the straightforward option, assuming Skipper is willing to be tethered. My outboard's lanyard is very short, but this might be (approximately) solved by attaching a short lanyard to a jackline. When the jackline is yanked, the lanyard is pulled. Better yet, an electronic strain gauge could sense tension in the jackline and trigger the stop-device. As backup, Andy's trailing safety line could also be similarly linked to the stop-device.
Unfortunately, articles I've read imply that simply being tethered is better than nothing ... but not really a solution. Even at a speed of only 3 knots, it seems many, perhaps most, would be unable to recover to the transom. Ergo, some sort of stop-device is really needed.
Perplexed .... :|
Posted: Fri May 27, 2005 10:06 am
by Chip Hindes
Andy wrote:If sailing, the boat is not likely to be going more than 7 knots, which would allow you to climb back on pretty easily.
Nice thought. I suspect you've never tried it. I don't believe there's a chance in hull you can pull yourself back to the boat against six or seven knots of forward motion; even three or four knots would be damn difficult. Don't forget you'll be additionally burdened with with your (hopefully) auto-inflated life jacket, shoes, possibly jackets, street clothes, etcetera.
Posted: Sun May 29, 2005 5:09 pm
I think you might have a chance if you can get back to the transom
One feature of our boats is a lot of transom turbulence where you would not feel as much of the potential 7 mph current.
How are you going to get back there i f you are tethered?? D*** if I know...
Posted: Sun May 29, 2005 6:28 pm
by deacm
OK, I installed yesterday my new Raymarine ST100 wireless remote on my ST4000 Autopilot. It installed in 5 minutes and worked like a charm. It's waterproof, so as long as you start pushing the 'turn' button before it has sailed 35 feet away from you, you might have a chance of putting the boat in irons before you are left behind when singlehanding. Might make an interesting MOB practice :-)
Posted: Mon May 30, 2005 7:23 am
At hull speed your prize is doing 10 feet per sec away from you, so thats 3.5 seconds from falling OB give-or-take to get your boat into irons..thats awfully quick response from shock etc...
First line of defense has to be make darn sure you stay on board, although this thread has made me aware that I havent thought enought about getting back on while tethered.....Hmmmmm
