Re: Rudder depth
Posted: Fri Feb 25, 2022 8:37 am
Hi Warren631!
Might it be suggested that one might want to initially make it adjustable to move it fore/aft to balance the rudder forces.
You probably already know this but, If the addition is too far forward of the pivot it will tend to over steer getting progressively worse as the turn increases. Similarly if too far aft the force to turn becomes progressively harder.
Your sketch has increases both fore and aft of the pivot axis.
Might it be suggested to approach this at least initially to locate the added piece proportionally similar to the original design rudder?
If the original had say 15% of its area ahead of the pivot axis to then position 15% of the added section ahead of the pivot axis.
Just a suggestion.
Your boat, your rules.
Best Regards
Over Easy
That is a good idea to regain some of the rudder control wetted area….Post by warren631 » Fri Feb 25, 2022 12:37 am
I'm thinking of shortening my HDPE custom rudder by cutting 26" off the bottom and attaching this 26" x 12" piece across the bottom using HDPE epoxy and SS screws as indicated in attached sketch so 20" is behind and 6" is in front of the pivot axis giving a balance of 30%. The square inches in the water would be the same but the depth would be 26" less.
Just a suggestion.
Best Regards
Over Easy
