Re: Honda BF50 "kicking" in reverse
Posted: Wed Jun 10, 2020 9:52 am
No one mentioned anything about bearing failure.Highlander wrote: ↑Tue Jun 09, 2020 10:20 am #1 a wheel bearing failure is a way more catastrophic an event "think " of a wheel flying off going down the road & what that could detail ? plus now u r draggin ur boat & trl frame on the ground while maybe sliding into a ditch or another car ?
We went with hammer and lots of WD-40.Highlander wrote: ↑Tue Jun 09, 2020 10:20 am #2 A brake failure "seized" is easily released thru either opening a bleeder on said brake or loosen the brake line & maybe require prying the brake caliper open .
I wouldn't take offense at that, except...Highlander wrote: ↑Tue Jun 09, 2020 10:20 amI,m qualified to drive 18 wheelers so this would b no problem for me , but I would recommend a tow company in ur case
This sounds awfully judgey.Highlander wrote: ↑Tue Jun 09, 2020 10:20 am #6 All ur dilemma,s r self inflicted wounds caused from lack of concern for safety , reg. maintenance, reg. inspections , do u even know what a circle check is !
Just sort of "free-range" judginess then?
It was offset, but not dangerously so. It was not rubbing, but an couple of inches away.Highlander wrote: ↑Tue Jun 09, 2020 10:20 am #4 U actually drove a boat sitting on a trailer improperly rubbing & or pushing a fender up against a tire " really" or r u saying it moved while trailering
Went to the mechanics with no trouble.
Checked it before heading back, and it was the same - a comfortable gap.
But it was definitely seized.
I checked it, but it still had a gap. This is why I dismissed it at first.
That's why I suspect it was a combination of a seized brake and rubbing.
Who mentioned anything about an unsecure load? (OK, sure, but you didn't know that.Highlander wrote:Tue Jun 09, 2020 10:20 amdriving an un secured load down the road is a MAJOR SAFETY driving violation & can only b done with police & proper emergency vehicles in rare exceptions & only to get said vehicle off the road in the shortish distance poss.
At first, we only had a 1 7/8 ball. And the to vehicle was (surprisingly) small. I hadn't known that when I asked my friend for help.Highlander wrote:Tue Jun 09, 2020 10:20 am#5 Not sure u had the right ball size on the tow vehicle or if tow vehicle was adequate ?
One of my going theories was that the tow vehicle (a small pickup) couldn't support the tongue weight, and thus the trailer was sloping into the hitch, meaning the surge brakes were locked.
When I switched to a larger tow vehicle, with a two inch ball I was able to invalidate that theory - the wheel was definitely still locking. So it wasn't just the inadequacy of the tow vehicle.
Back at club without further incident.Highlander wrote:Tue Jun 09, 2020 10:20 am #8 Now that,s off my chest , lets us all know what the final resolve of ur issue ! comes out to B ?
May never really find exact cause, but take-away lesson is:
1. Ensure adequate power, height and suspension of tow vehicle, proper ball size.
2. Boat MUST be centred when hauled out.
3. Secure boat against shifting, even on short runs.
4. Beef up fenders to prevent rubbing.
5. Oil and check tongue/brakes prior to trailering.
6. Do a circle check.
7. Obviously, keep trailer properly maintained, and check regularly before and after any trip.
