Page 3 of 4
Re: What goes here? What is this for?
Posted: Thu Apr 02, 2020 10:38 am
by Jimmyt
BOAT wrote: ↑Thu Apr 02, 2020 10:03 am
Extra bracket is for the sail tack - you would not have that Jimmy because your sail is attached to a furler - not to the mast.
Got it. Thanks for clearing that up!
Posted: Thu Apr 02, 2020 11:43 am
Are you talking about the "hook" that your main halyard is hooked to?
I thought that was used for reefing. My tack is connected to a connector attached to the bolt. (don't have a photo).
As BOAT mentioned, yours is attached to the furler.
Posted: Thu Apr 02, 2020 12:12 pm
by Jimmyt
It will be so obvious to you that you'll think I'm a knit wit (which will be true).
The tack connection at top of gooseneck pin, next to reefing hook. I don't have one as BOAT pointed out, so I didn't even think about where you guys connect the tack.
Posted: Thu Apr 02, 2020 12:35 pm
by BOAT
Posted: Thu Apr 02, 2020 12:42 pm
My theory is Inmon took standard Mac and modified the boom. Didn't bother to cut that off in case the owner chooses to restore to OEM style main.
If it doesn't get in Jimmy's way, I'd just leave it.
Mine DOES get tangled often.
Posted: Thu Apr 02, 2020 2:17 pm
by Jimmyt
Are you guys referring to my main halyard head connection storage hook?
Believe it or not, that's the only thing on the mast I haven't tangled up.
Posted: Thu Apr 02, 2020 2:51 pm
Jimmyt wrote: ↑Thu Apr 02, 2020 2:17 pm
"main halyard head connection storage hook"
I never thought to use it for that. I have always used the mast raising vang for the main halyard. I like your idea.
My main seems to constantly get tangled. I've been saying I need to put something over the "hook" to keep the main from tangling. Maybe with all this time at home I can engineer something. Wish I had some of those welding skilz like you.
Posted: Thu Apr 02, 2020 4:26 pm
by Maraquita
Thanks Boat, that gives me a whole new way of looking at the traveller problem. Maybe put track on the floor and both gunnels and just move the sheet attachment as needed? Might be interesting!
As for the rivets in the gooseneck fitting, I installed what were supposed to be high-strength Aluminum in mine and they only lasted one sailing season. The holes in the mast were wallowed out so these were #5 AL rivets with steel centers. The second time around I had to go up to #6 rivets and I used Stainless Steel. 5 years now and no sign of looseness. But boy do those puppies take a massive "armstrong" puller to get them set!
Posted: Fri Apr 03, 2020 5:07 am
by adudinsk
The bracket appears bent, because its so loose.
Posted: Fri Apr 03, 2020 5:08 am
by adudinsk
Also were the stainless steel rivets of POP type.. did you need a special pop rivet tool?
Posted: Fri Apr 03, 2020 6:36 am
by Jimmyt
Yes. Stainless pop rivets. Mine are still factory. I don't know if I can do one by hand. I'll go try. Or not... out of steel pop rivets - sorry. Doubt you can do it with the standard tool though. A heavy duty type or pneumatic may be required.
I'll bet someone on here has done it. But, I wouldn't use aluminum rivets on the boom. Factory rivets are stainless, I'm virtually positive. Very hard to scratch with a sharp center punch...
Posted: Fri Apr 03, 2020 6:50 am
by Jimmyt
Your gooseneck bracket is bent and your mast connection is loose. Somehow, that appears to have been mishandled. Is this previous owner damage, or are you using your boom for a jungle-gym?
Posted: Fri Apr 03, 2020 7:23 am
by BOAT
Maraquita wrote: ↑Thu Apr 02, 2020 4:26 pm
Sure thing Maraquita and that's exactly what I do when I want to point really high so the boat weighs about 2500 pounds so I have a Ronstan 2420 snap shackle on top of the traveler so i can move the mainsheet but in the case of your wife not wanting the sheet block in her way you might consider a trapeze mainsheet - they were VERY popular back in the day before travelers caught on:
The trapeze mainsheet would go from one edge of the cabintop to the other and preserve a little 'teepee' opening over the companionway for your wife. That's not really the best way to deploy a trapeze - these were VERY VERY common in the old days and the real advantage is they work well to flatten the main when beating hard into the wind when they are deployed from the end of the boom:
The boat is pulled through the water at the points where the sail attaches to the boat - so most of the pull is exerted through the mast and shrouds but a huge percentage is from the mainsheet block and the gooseneck. Really important to make sure those two things are well secured.
Posted: Fri Apr 03, 2020 11:02 am
by Jimmyt
This one will do stainless rivets according to reviews. Pretty cheap. I may need one of these. I wish I felt safe going to HF now. Wife wouldn't let me go anyway, though so I'll have to wait... never met a tool I didn't need.
https://www.harborfreight.com/heavy-dut ... gL5L_D_BwE
Posted: Fri Apr 03, 2020 11:40 am
by Tomfoolery
That looks like the type you should be using for SS pop rivets - compound action, two hands required.
Or a pneumatic/hydraulic type.
