Posted: Fri May 06, 2005 3:05 pm
I contacted Steve Leone, the Ebay seller of the pee-hole flusher, about my problem. Here was his response:
"You may have had too much salt build up prior to use. Either that or there was insufficient water pressure. I have a commercial client that has a Honda 50 and has only been using the flusher since new. After two years we pulled the stat cover and it was near pristine. You may need to change the thermostat and increase the water flow. When you turn the hose on make certain water is coming out from the water pick-up on the lower unit. This is an indication that the thermostat or poppet valve has been opened or not. Thanks, Steve."
It is possible there was buildup from the previous owner. I had said the motor was used by the PO in fresh water but that is not true, it was brackish. How brackish I do not know (Fort Belvoir, MD, near DC). So maybe there had been prior buildup.
My water pressure is good, and water does come out the lower unit, but maybe there was sufficient buildup that the thermostat couldn't open enough to flush the old buildup out. I never had any overheating problems.
I had talked to Steve Leone last year before I bought the flusher and he seemed like a pretty straight guy.
This year I plan to use the flusher primarily, with an elephant ears flush when convenient. Then I will check it at the end of the season.
The Honda manual recommends an annual check of the thermostat anyway.
