Page 3 of 3
Re: Advice on fuel system / water separator racor
Posted: Fri Apr 13, 2018 12:22 pm
by Highlander
whgoffrn wrote:And an update on mine is ....despite racor advising against yellow Teflon tape I wish I had used it....the liquid thread sealant stuff STILL has not dried....i guess maybe it never does??? So yeah now I'm considering taking apart all the connections to use the yellow Teflon tape
I used Perma - gasket liquid paste its oil & gas resistant & yes it never completely dries not sure what ur issue is with that anyway ? unless u plastered it on big time :P
Posted: Sat Apr 21, 2018 4:29 pm
by whgoffrn
Well if there are any others wondering which comes first the bulb or the filter I'm now a strictly bulb first kind of guy
This is a pic of what my new racor filter caught in the fuel
This was using a brand new gas tank and new lines so I knew it must have been the bulb ...sure enough I cut the bulb open and found black tar like stuff everywhere....where the fuel had ate away the inner lining of the bulb....if I had put the bulb after the filter all of that sludge would have went into the engine
I would have never thought a primer bulb could disentegrate like that
Posted: Sat Apr 21, 2018 4:40 pm
Yikes, what a mess.
Was the bulb hard to work, or was it still 'normal'? I'm asking because I have a retired bulb and hose that I use to transfer gas (petrol) but after seeing that I'm getting a bit concerned.
Posted: Sat Apr 21, 2018 4:47 pm
by whgoffrn
No it was working perfectly fine .... last thanksgiving I took the mac to Florida to stay a week on it wouldn't run right for the first 30 mins ...i switched tanks thinking I had bad gas ...and it started running better so I blamed it on bad gas but now looking at that mess I bet it was the bulb....i had been using that bulb without any problems for years
Posted: Sat Apr 21, 2018 5:55 pm
by Highlander
My Merc 75HP 4 stroke has a low pressure fuel filter just inside the engine cowling & then a second high pressure fuel filter on the high fuel pressure side just before the fuel injectors both r transparent filter bodies so u would see the crap inside them , I always check them when I check my eng. oil level
Bu remember if the fuel bulb is that bad so r all the fuel lines external & internal !
