whgoffrn wrote:...
1. the front stay ....ive gotten one of the larger size from bwy and I also tie a small yet strong 2klb rope to the top of the mast as a back up plan ...keep the original on the boat...i actually have replaced all the stays and keep the originals on boat as backups..
Good upgrades that will give you more peace of mind.
whgoffrn wrote:...
2. rudders And brackets...i have a 99x with the stainless steel brackets and I have a shark drogue I got from fiorentino as a back up to steer with drogue if necessary...
I question if you will be able to do much meaningful steering with the drogue. Keep us updated.
On the rudders, Mike and Sandy have been to the Bahamas I think 3 times now with their X and also to Alaska and back, Sea of Cortez and the Great Loop. Might check to see if they have done anything or not with the rudder/brackets.
I had my cheek plates fail coming back from the Bahamas that resulted in loss of steering when the rudder folded up. I was lucky and this happened on the way back 4-6 miles off Florida. 25, 50 or 100 miles earlier it would of been a real mess. I have tow insurance so finally gave up on trying to get the outboard down and got towed in.
I don't think this was a sudden catastrophic break and feel you won't have one either. I think it cracked and then over time the crack lengthened and finally broke. I had heard a strange clicking before but could never find out where it was coming from. In the future I will keep an eye on the bracket much more often.
Saying that I feel you will be fine, but keep a closer eye on those brackets and such so you don't get a sudden surprise. Not easy to find help over there but I'm sure if I would of found the problem earlier I could of done something to of helped it out.
whgoffrn wrote:...
3. I'm not sure I've seen this as a problem but I've had a 3rd higher reef put in my main and a roller furler so I can really cut down on size of canvas
I think the 3rd reef was a good move. When I ordered our main from Martin at Somerset Sails I went with just one higher reef about where a normal second reef is on the recommendation of another Mac sailor that knows more than I do about sails. 90% of the time it worked great but as I tried to sail only going over as much as possible and most of the way back there were high wind days when the main still had too much sail area and the boat was difficult to sail at times.
Martin said that if I ever wanted another higher reef he would add it at no charge. I sent the sail back after the Bahama trip and he put in the higher reef, about where a 3rd reef would normally go in. On our Flaming Gorge trip and our recent Lake Powell trip we could now sail in 20-30 knot winds with much better control.
Being able to sail reliably is a big safety factor when over there. With the easterly's it is hard to sail over there until you get by Nassau where you turn SE to the Exumas and don't have the wind on the bow any longer. If you did have engine problems with the prevailing easterly's sailing all the way back to Florida is not hard to do. I sailed 99% of the way from the Exumas to West End only using the outboard to go in a couple places. I did motor back across the Gulf Stream as there was a 1 day window to make the trip and the wind was not conductive to sailing. Worst case and I could of hung out at West End for a better wind day to return.
whgoffrn wrote:...
4 water in gas or crappy fuel.... I haven't yet but plan to get a water separator in fuel line and fuel tester
I...
http://purplesagetradingpost.com/sumner ... de-36.html
.... run a water separator/filter on the fuel line and use...
https://www.walmart.com/ip/HOPKINS-F3C- ... 3=&veh=sem
... one of these filters to pour fuel into the inboard tank. I think fuel over there is now much more reliable than it use to be. Not sure I would bother with a fuel tester. Put in the inline filter and use the other filter when you get fuel.
whgoffrn wrote:...
5. Lack of storage .... I don't plan to store water on boat as I found a reasonably priced water maker and i have lined my boat in cargo netting on insides to aid in more room
I wouldn't put all your water needs in the hands of a water maker. I'd at least take a number of collapsible water containers just in case you have a problem with the water maker. There is a lot of room in a Mac. We can pretty easily provision for a month or more for the two of us for all our water, food, fuel and sanitation storage needs. I don't have much more storage on the 37' Endeavour (a lot more living space of course
) In your case with 2 children I put them in the V-Berth and partition off one side of the aft-berth for yourself and the other side for storage.
Be cautious but don't spend too much time trying to figure out everything that could go wrong and stop you from going. Your big safety items are good navigational skills with backup (charts and two sources of chart plotters) and being very flexible on when you move, especially across the 'stream' and the longer passages in the Bahamas,
Sumner
The MacGregor 26-S
The Endeavour 37
Mac-Venture Links
