Re: Table/Bench Seat Mod
Posted: Tue Dec 07, 2021 10:44 am
When I was at the factory taking a tour of the MAC70 they told me that sweating was a new problem that occured when they started putting fiberglass liners in boat. The full hull liner in the X boat was considered an added feature at the time. You can see here that the liner for the X boat is a FULL liner that covers the entire hull for added insulation:
This made good insulation in the X boat, but also resulted in moisture, so when they made the M boat they added another layer of fiberglass to the hull and just skipped the hull liner altogether:
So when they did the M boat there is no liner on the hull - they are just bare walls covered in carpet:
This did stop the sweating along the hull where the beds are. It did not completely stop ALL sweating - if you load up the M boat with 5 people all sleeping at night on a cold day you will get some moisture on the upper liner.
The marine plywood with the teak and holly should be able to take moisture if you finish both sides with Epiphanes - I did both sides lightly.
