Twin daggerboards I get. What if you canted them out so when you are heeled over 10 to 20 deg the boards are stright down to be more efective? However lift=drag. With the dagerboard 1 to 2 foot off of centerline at best you will get 2lbs of righting moment for every 1lb of lift. Probably will be more drag than power?Chopper Pilot wrote:The hydrofoils are horizontal, which is perpendicular to the daggarboards. This allows the vertical forces to be applied to each side.
There are some righting foils made that stick out of the side of the boat. They help a little but most are about 10 foot off of centerline. 1lb of lift would give 10lbs of righting moment.
