Page 3 of 4
Re: Quick heron H-412_D Windlass
Posted: Wed Apr 24, 2013 1:10 am
by Highlander
Posted: Wed Apr 24, 2013 7:12 pm
by waternwaves
Still waiting to see the pics of this install John,
Posted: Thu Apr 25, 2013 1:21 am
by Highlander
waternwaves wrote:Still waiting to see the pics of this install John,
Hi Darren
U'll just have to wait like everyone else !! LOL This is a big project & the weather has not been co-operating even though I am doing most of this project inside my none heated shops as I am toooo cheap to pay to heat them
, but alot of the concept & designing & engineering of this mod is basicaly play as u go , figuring angles & cocepts that r desireable but main issue is strength combining both deck & hull into one good strong anchoring base
keep watching
Posted: Mon Apr 29, 2013 5:03 pm
by Highlander
well slowly but surely she's coming along , here is a pic of the sticky backing tape i bought & used on the inside anchor locker brkts & on all the SS washers
http://i844.photobucket.com/albums/ab1/ ... a47c89.jpg
cut into strips two on the anchor locker walls & one each on each brkt
http://i844.photobucket.com/albums/ab1/ ... 8cf42d.jpg
http://i844.photobucket.com/albums/ab1/ ... 2215c3.jpg
Here is the center anchor locker brkt now temp installed has one more coat of paint to get
http://i844.photobucket.com/albums/ab1/ ... 3d6477.jpg
http://i844.photobucket.com/albums/ab1/ ... 1bd265.jpg
http://i844.photobucket.com/albums/ab1/ ... 22ff87.jpg
the final coat of red flrorecent paint when that dries this brkt will be mounted i picked this colour so as when the anchor locker is open theirs no mistake in knowing it !!
http://i844.photobucket.com/albums/ab1/ ... 62fda4.jpg
Here's another short vid of my swivel mounting brkt I will post another vid of it when completed without the windlass on it to let u see the mechanisim better
http://s844.photobucket.com/user/TheHig ... 4.mp4.html
Posted: Thu May 09, 2013 9:50 am
by Highlander
Posted: Sun May 12, 2013 3:00 pm
by Highlander
Posted: Mon May 20, 2013 7:55 pm
by Highlander
things are moving along slowy fit , retro fit , refit , a very slow process
Here's the finished timing plate top side
http://i844.photobucket.com/albums/ab1/ ... c22025.jpg
here is the bottom side
http://i844.photobucket.com/albums/ab1/ ... 83f921.jpg
http://i844.photobucket.com/albums/ab1/ ... 1ab0f1.jpg
middle spacer plate could not find a gasket to fit the center hole where the main wiring goes through so i used a sink drian plug & cut out the center for the wiring to go through
http://i844.photobucket.com/albums/ab1/ ... 1c8b41.jpg
http://i844.photobucket.com/albums/ab1/ ... 6f588e.jpg
http://i844.photobucket.com/albums/ab1/ ... 5c05ba.jpg
here r the mounting bolts with large fender washers insulated with rubber backing
http://i844.photobucket.com/albums/ab1/ ... 07532f.jpg
Here is the hole drilled through the deck for the battery & control wiring
http://i844.photobucket.com/albums/ab1/ ... 6bf6ba.jpg
http://i844.photobucket.com/albums/ab1/ ... f6cee5.jpg
here is the 1 1/2" conduit piping installed through the V - Berth floation chamber so from now on I can easily run elect. wiring through there, no floation was removed for this mod
http://i844.photobucket.com/albums/ab1/ ... 71f239.jpg
http://i844.photobucket.com/albums/ab1/ ... f7978b.jpg
here is the aft end of the v- berth conduit this is the elect horn wiring still to be installed
http://i844.photobucket.com/albums/ab1/ ... e8f2ca.jpg
this is where the battery cables for the windlass will be fend through to the bow
http://i844.photobucket.com/albums/ab1/ ... 88091d.jpg
All put back together nice & tidy
http://i844.photobucket.com/albums/ab1/ ... 665c24.jpg
Here's the finished stage two now it's into stage three running the 1 1/2" elect conduit for the wiring
http://s844.photobucket.com/user/TheHig ... a.mp4.html
http://s844.photobucket.com/user/TheHig ... 6.mp4.html
Well got to run another 24 ft of 1 1/2" elect. conduit through the boat then install the wiring , reverseing relay , battery ect.
Posted: Sat May 25, 2013 8:27 am
by Highlander
had some running around to do yesterday so progress was slow the electrical cable through deck base was fitted & sealed with 5200 & left to set , then moved onto the electrical conduet I used 1 1/2" but I think 1 1/4" would have been ok this will allow me to run all my electrical cables 12v & 110v down the port side that have to be route there outlets at each end bow & stern & midships for any future wiring I may run halfway
http://i844.photobucket.com/albums/ab1/ ... 67cab0.jpg
http://i844.photobucket.com/albums/ab1/ ... 956356.jpg
http://i844.photobucket.com/albums/ab1/ ... eef483.jpg
http://i844.photobucket.com/albums/ab1/ ... ae21b2.jpg
http://s844.photobucket.com/user/TheHig ... 2.mp4.html
Posted: Sun May 26, 2013 9:28 am
by Highlander
Hi All
Stage three is coming alone slowly installing the electrical conduet that the windlass battery cables will be route through & some other wiring that is already there will be removed & reinstalled through the conduet & reconnected , unfortuantly I had to remove my 3" return air ducting for my bilge pump so as I could get the 1 1/2" conduet installed where I wanted it , so after I finish off installing the aft section of the conduet to-day or untill I run out of material I will then reinstall the 3" air ducting, then once the run of electrcal conduet is done I'll be able to measure my elect. battery cable length & @ $5 a foot I do not want to be buying to much excess
http://i844.photobucket.com/albums/ab1/ ... 58c754.jpg
http://i844.photobucket.com/albums/ab1/ ... 07af24.jpg
http://i844.photobucket.com/albums/ab1/ ... df054c.jpg
http://i844.photobucket.com/albums/ab1/ ... 264d2c.jpg
http://i844.photobucket.com/albums/ab1/ ... 77564a.jpg
http://i844.photobucket.com/albums/ab1/ ... 92cfb3.jpg
http://i844.photobucket.com/albums/ab1/ ... b10164.jpg
http://i844.photobucket.com/albums/ab1/ ... 46b6c2.jpg
midship outlet so as I can bring wiring out there for future mods if needed
http://i844.photobucket.com/albums/ab1/ ... cd4fd4.jpg
http://i844.photobucket.com/albums/ab1/ ... c06b42.jpg
http://i844.photobucket.com/albums/ab1/ ... 315e91.jpg
http://i844.photobucket.com/albums/ab1/ ... a6093e.jpg
The elect. conduet going down the port side is zipped tied up into postion I have to make approx 5 brkts for this to make it a pernament fixed mounting this allows me to get my fixed brkt's mounting possitions but I will just leave the zip ties there anyway, that way if I have to remove the brkt's for any other future mods or alterations the conduet will still be held in its installed position
Posted: Mon Jun 03, 2013 1:24 pm
by Highlander
Posted: Tue Jun 11, 2013 9:07 am
by Highlander
Just ordered 30ft of tinned #6 twin sleeved dual battery cable @ 5.00$ a foot
, should have it for fri
Took Sun off from working on the boat & took my youngest daughter & gran daughter to the big TO Zoo seen the Panda's , white South African Lions , Elephants , toured the whole we all had a very enjoyable day, the weather was just great to 24C nice sunny skies
Posted: Sun Jun 23, 2013 5:33 pm
by Highlander
She 's wired up from main independant house battery in the V-Berth work's like a charm power"s up & down or free=fall down ur choice
, also running extra wiring for any future mods , already run wires all through the top head liner that was a major pita
have now run about 45 ft of # 6 wiring from bow bat to first house bat next to the start bat under the ladder with a kill switch just have to hook that up now but @ 90% in the shade 3 fans running it was a killer
Still have to run about 36ft of # 18 wiring from the reversing relay to the cockpit control switch in the pedestal
will post pic's later J
Posted: Thu Jun 27, 2013 9:27 am
by Highlander
Battery hold down for the V-Berth the backing plate went into the inside of the floatation chamber under the V-Berth
http://i844.photobucket.com/albums/ab1/ ... 81532d.jpg
Here's what 60ft of # 6 battery cable looks like tinned
http://i844.photobucket.com/albums/ab1/ ... 1419b7.jpg
hooking up batt cables to batt switch & kill disconnect switch
http://i844.photobucket.com/albums/ab1/ ... b57ceb.jpg
http://i844.photobucket.com/albums/ab1/ ... 3066c5.jpg
Battery & solenoid, circuit breaker installed & wired
http://i844.photobucket.com/albums/ab1/ ... 49227e.jpg
http://i844.photobucket.com/albums/ab1/ ... 48aea6.jpg
http://i844.photobucket.com/albums/ab1/ ... dd7e02.jpg
More to come vids of windlass operation , now still have to run 36ft of # 18 wiring back to the pedestal for cockpit control switch will post later
Posted: Thu Jun 27, 2013 12:11 pm
by Crikey
Becoming more impressive all the time!
I will give it the once over at this year's rendezvous - if there's and room left inside the boat!
Any hints for the next planned mod?
R.
Posted: Thu Jun 27, 2013 2:10 pm
by u12fly
Be nice to know the total weight for this installation.... windless, mount, extra battery, wire, etc.
