I am sorry Dave, but IMO, a 12 foot 2x6 would have been unnecessary. I am a mechanical engineer and was very comfortable with the bending stresses that were applied to the mast. By supporting the mast with the carpeted wooden blocks that locked the long axis of the cross section in the vertical direction, this ensured the largest moment of inertia was available to minimize the tensile stress caused by the bending. Furthermore, when I adjusted the tension in the front tie down, it was done to place only a slight bend in the mast to keep it tight, but not too tight. The tie downs over the roof rack were very tight. I also tied another set of lines from the forward part of the roof rack to the bail bolted to the mast to help prevent sway and stop forward motion if we had to stop quickly. The mast was locked into place and barely moved during our 180 mile drive. With a 70 mph speed limit in Washington state, we had no problems going 70-75 most of the way. When we hit a bump, it sprung up and down a little but quickly dampened out. There were no resonant oscillations. I did not notice any side to side motion.DaveB wrote:The Mast on the M and X is not strong enough for the large amout of over hang for a 2 point support system that is 5 ft. or less between supports. Adding a 12ft. 2x6 under the mast would give much more support.
Years of experance and FL. Certified Lic. Structural building/ and Certified Building Lic., I know what am talking about.
Aluminum, steel, wood fastners are just a few things to know in my trade.
Putting a 30 ft. Mast on a suv with supports 5 ft. is not the way I would do it.
The cross sectional area moment of inertia would be very difficult to calculate since it is a complex cross section with the shape, the sail track, and the wall thickness that varies from about 0.085" to 0.130". If I had the moment of inertia, I could calculate the stresses with the maximum deflection that
I had of about 4". I would be willing to bet that it was easily less than 20-30% of its yield strength of 40,000 psi.
When you rig your mast to the boat for towing and have it bolted to the bow pulpit and mast crutch, there is about a 22 foot length between that is unsupported. If you hit a bump while driving down the road, the mast will bend at least as much as it did as I had it rigged on the Rav 4.
The wind loads on the mast were negligible with the mast pointing right into the wind. The cross sectional area that was presented for any side wind (bare pole) is really small compared to having sails out.
The drive was really relaxing and pleasant. Much less stress than towing the boat. If necessary, I would do it again. But now that my boat schooled me with the importance of the proper tuning of the rigging, I am hoping that this mast will last a good long time.
But hey, we are all entitled to our opinions.
Happy Sailing
Bob
