Page 3 of 3
Re: Further CDI furler questions
Posted: Sun Aug 07, 2011 6:07 am
A couple of pictures of the CFI FF2 Furler on an :macx:
Mine is on a Johnson quick release lever which moves it up about 8 inches off the deck and mast, but the bottom mount isnt changed
Couple comments
1 I start with the halyard and head of the sail as far up the extrusion as I can - when you pull the sail luff taut and stretch it down it comes about 4 inches in my experience.
2 The slot in the extrusion where you feed the boltrope is about a foot above the the ring in this picture - I push the bottom bolt rope down so that the entire bolt rope is in the extrusion. You have to bend the sail a bit to get this done but it will give you that extra 0.001 knot speed.
3 Note the pin/ringding on the green plastic cup - this is the one you remove to push the cup up the extrusion to check your bearing/turnbuckle
Posted: Sun Aug 07, 2011 9:01 am
by Highlander
enufsed wrote:
vizwhiz wrote:enfused - there should be a hole in the end of the threaded part that is in the turnbuckle...you just twist a small piece of stainless wire through that hole and around the body of the turnbuckle to keep it from turning. That's the main issue - people adjust them and then forget to wire them again, and they can un-do themselves over time...wire it up once you've adjusted the length to what you want, and you'll be fine!
Happy Sailing!
I will check that sometime soon. I've had the mast up and down quite a few times recently and can't stand the thought of doing it again right away. But I will check it. I hope that I can raise the black plastic piece above the drum enough to see the bottom of the turnbuckle -- things are fitting pretty tight and I don't have a lot of room at the top of the furler either. I'd prefer not to have to dismantle the whole thing.
Hi
If your still having issues PM me I just serviced both my CDI furlers as I am prepping my MAC19 for sale
http://s78.photobucket.com/albums/j95/m ... 010087.mp4
I'm busy getting the mac19 ready for sale but I go down to the big TO now & then to see my youngest daughter so maybe one of these days we could meet & look at your boat & see what the issue is !
I removed the Mac furler from my M & installed two Harken 00 Furlers
