I'd like to respond to a couple items in this thread and hope no one takes offense.
mastreb wrote:Look to solar as a battery topper. It will _never_ run an A/C unit, a refrigerator, or your electric prop, unless 2X the deck area of a Mac is covered in solar cells. The purpose of solar is to top off your battery while your boat is waiting for you, not to run any constant loads. 20 Watts will do that just fine.
I agree that solar might not run A/C or an electric prop, but it can fulfill over 90% of your electrical needs on the water if you install enough and use it wisely. We have had 180 watts of solar on the boat since last fall and used it for almost a month in the fall (Thanksgiving to almost Christmas) in Florida and again this spring for 7 1/2 weeks (March-May).
We do derive some elect. from the outboard while motoring, but it is only 6 amps max and usually don't see that on the amp meter. We also have a 12 volt gen-set....
http://purplesagetradingpost.com/sumner ... de-13.html
...I built using a Honda 5 HP engine and a GM 63 amp alternator. Our electrical usage is: a 63 quart EdgeStar frig. that draws about 3 1/5 amps when running; a CPAP machine at night for me that that draws 1 1/2 amps or so for 7-8 hours, the 12 volt computer I made that draws 2.8 amps when the long distance WiFi is running (probably used it at least 4 hours a day); also use the computer running SeaClear as a chart plotter while underway all of the time and also the handheld Garmin Map 76 runs off the ships batter while underway; a Cuda 350 GPS/depth/fishfinder while underway; the anchor light every night and we also use a little electricity to recharge some tools and other electronics.
On the fall trip we sat on anchor a lot with one cold front after another going through but did manage to go about 130 miles. The days were short and the sun angles were low and we did have some clouds with the fronts. If I remember right we had to supplement the solar with a couple hours total of running the gen-set on the trip. All of the rest of the electrical needs were supplied by solar with also the outboard a couple days.
We had the same electrical usage for the 7 1/2 week spring trip and there again probably ran the gen-set a total of 2-4 hours total for the trip. This trip was a little over 400 miles down the west coast and over to the keys and then north to south of Miami and we did motor quite a bit, but still we spent a lot of days on anchorage enjoying different locals, usually 2-5 days.
Temps were in the mid to high 80's for the last month of the trip and the frig ran a lot more than in the fall. We usually got it down to 37-38 before the sun went down and turned it off for the night. Then would turn it back on the following morning around 9 am or so. It usually was off for 12-15 hours and during that time would climb to 44-45 deg. Then it ran most of the day for about 8-9 hours straight, so it ran about 30% of the day. We kept it full and really put a load on it as when we had a chance to buy fresh food we filled it and then as that was used we added pop and beer, so it was full most of the time. I've read that at about 95 deg. an air cooled compressor frig is about maxed out as it can't get rid of the heat at 95 and above. We were getting close to those temps inside the boat at the end of the trip. Considering the conditions the frig impressed me and we would buy another.
So all in all solar can supply most if not all of your energy needs on the water.
Divecoz wrote:..... Solar seems to be the answer ... its the cost and the location of the panels that is the problem!!!.. I refuse to have my boat look like a jungle gym that was assembled by Fred Sanford and Lemar!!!!
Yep if you are going to add enough solar for serious cruising and want to be out for more than a couple days the looks of your boat are going to have to change. We have a lot more than solar hanging on the boat and it isn't beautiful anymore....
.....but it sure is functional and we will take that over the alternative for what we want to use the boat for.
I'm changing out one 80 watt panel for a 100 and that will give us 200 watts total. I would sure recommend 80 as a bare minimum if you want to run a frig and over 100 would be a lot better. Your panels are never going to put out max wattage due to the compromised sun angle and then only for part of the day.
We are putting 480 watts on the new boat. We have the panels, I just have to make a mount to take back with us. One thing I would recommend if you are in an area that has pilings or are going to such an area, and that is, don't have anything sticking out further than the rub rails on the boat. I can tell you that from personal experience
Sum
Our MacGregor S Pages
Mac-Venture Links
