advice on autopilot for Mac26M
Jim Bunnell
Re: advice on autopilot for Mac26M
Post by Jim Bunnell »
Also, what is that bracket pin for? It's supposed to mount on the pedestal, with the end of the pin just below the rim of the drive wheel. The mounting base is curved for a round pedestal, and the surface I will need to mount it on is flat.
The pin is to hold the wheel case in place and prevent it rotating. The motor tube is free-floating, so it would rotate if the wheel case was not anchored. Raymarine makes an adaptor for a flat surface mount. Being cheap (I know,if I were really cheap, I wouldn't own a boat :) ), I decided to anchor the motor tube (and thus the entire case) by passing it through a fixed plate. I used a piece of cutting board mounted to the pedestal. I added a piece of soft foam around the motor tube to keep it from rubbing directly on the plastic. You can see the back of the arrangement below Josh's left hand. If it ever stops snowing I'll try to get a shot from the front. It does put the clutch in an unusual place, but I grew accustomed to that easily. I've got a larger wheel, so I don't know what the clutch arrangement would be like with the standard one. I've used it this way for several years with no problems.
Phil M
Post by Phil M »
The Autopilot x-5 wheelpilot I installed last summer and posted to the mods
http://www.macgregorsailors.com/modt/in ... ?view=1389
was a worthwhile investment in sailing enjoyment, sailing solo or with a crew.
Phil M :macm:
MosheHaven
Post by MosheHaven »
The previous comments on this post appear to be on a much earlier model autopilot, in 2011. I just bought a Raymarine EV-100 for my 2011 Mac 26 M
The marina where they are installing a lot of other accessories for me essentially gave up on this. They said that it doesn't work with the flat plexiglass screen we have on the aft side of the pedestal extending down to the deck. They said it is made for fiberglass and plexiglass won't hold the pressure of the motor driving the wheel.
Does anyone have any advice on this? From what I've seen the EV-100 is commonly used on our boat so others must have found a way to do it.
Starscream
Post by Starscream »
Hi Moshe,
I commented on FB too. I don't have an M, but many owners have successfully and relatively easily installed an EV100 on a 26M like yours. I put a couple of links on FB to other threads on this site where there are photos of the EV100 installed on an M.
Where there is a will there is a way. Maybe ypu could post a couple of photos of your pedestal, so those of us who don't have an M but are familiar with the EV100 can visualize and give advice.
