Re: Re-powering a MacM from 70 HP up
Posted: Mon Dec 06, 2010 2:58 pm
Bob,
I can live with 14.5 inch wide but now you opened a new door to E-Tec 75 that you say is not much wider. If it's less than 17 inches I would be interested.
I may just go with the Etec 60 as it will probably do better than my Honda BF50. All I want is 2-3 knots more to get the boat on plane the way it should be. This means 16 knots unbalasted in a fully loaded (700 lbs more than stock) .
They say for every 100 lbs you load, it will require 1 hp more to push it, in a MacX I belive it's every 50 lbs to 1 hp. to get on full rpms and speed.
bscott wrote:Dave, the E-tec 60 power head is not a true rectangle and is 14.5" wide. The boarding ladder on mysits mid-way between the port rudder and the engine. Hope this helps. The E-tec 75 is not much wider than the 60 but I don't have the measurements.
Bob
