Re: Long Distance WiFi...
Posted: Mon Mar 22, 2010 2:35 pm
Arghhh - that was extremely punny!
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=15484
Are you saying that something at the top of a mast never gets wet? Although it never rains in Southern California (seems I've often heard that kind of talk before), it *does* tend to rain everywhere else once in a while... sometimes rather horrendously.... sideways, even. How does it never get wet?mlahrkamp wrote:...I don't think most ever have gotten wet....
A device that is designed to be permanently outside (like a chart plotter, navigation instruments, compass, antenna's, etc), should certainly be waterproof, in my opinion anyway, and certainly on my boat. I have enough things to worry about! My laptop is not a purpose built marine electronic, nor was my engine built be installed outside.There are many things on a boat that are not waterproof - few laptops are. Your boat's engine isn't either. What we do is use things for a purpose that is reasonable.
I am more than happy to take a photo of the inside of any Wirie that has been installed in the outdoors for over a year. We use no grease or magic, and the wiring and connectors look exactly the same as the day we manufactured the unit. That's why we do what we do, and why IP67 is actually important. I guess Raymarine, Simrad, and Furuno have it all wrong too.While on the topic of corrosion: Using an IP67 rated case not only seals out the environment, it seals it in as well.
Our customers are looking to get online, they don't really care if the access point is 1 mile or 10 miles away. If max range is the only important thing, a directional antenna is a better option anyway.If someone is looking for max range, higher is simply better again.
All the marina's I have stayed at seem to know what they are doing then, as I can connect with my laptop alone. Good marina installs wont consist of a single tower. They will provide access points at various locations throughout the marina to provide the best coverage for all their customers. It is after all in their best interest to get their customers online, since its a service they are offering to them.In a marina, sitting at the nav station, with an adapter card, you're usually at the waterline, often below dock level, with lots of metal boats and masts all around. These all conspire to absorb and reflect Wi-Fi signals.
Mark, you can rest easy, this post is being read, here are the stats. - Long Distance WiFi...P.S. I sure hope someone besides Mike and I are reading this.
I'm enjoying the discussions between the leaders of two manufacturers. Very interesting stuff.kiltym wrote:P.S. I sure hope someone besides Mike and I are reading this.
Yea.. I built a pringles cantenna years ago to "borrow" WiFi while visiting my dad who was on dial up.verena wrote:How to build a directional antenna out of some large cans and aluminum tape:
http://www.sailsarana.com/projects.htm#ANT
Regarding waterproof: Raymarine is only rated as "Fascia waterproof to IPX6 standards when console mounted." No statement regarding remainder of enclosure, only the front display.kiltym wrote:A device that is designed to be permanently outside (like a chart plotter, navigation instruments, compass, antenna's, etc), should certainly be waterproof, in my opinion anyway, and certainly on my boat.
I indicated that condensation requires a temperature change, something that does not really happen in the Caribbean. Nevertheless, any sealed volume that contains moist warm air and then cools to below the saturation level of the air, will form condensation. If it is salt air, expect more issues. One minimizes this effect by reducing the volume of the space so that minimum opportunity exists, uses a desiccant or provides ventilation (negating the sealed environment).kiltym wrote:I am more than happy to take a photo of the inside of any Wirie that has been installed in the outdoors for over a year. We use no grease or magic, and the wiring and connectors look exactly the same as the day we manufactured the unit. That's why we do what we do, and why IP67 is actually important. I guess Raymarine, Simrad, and Furuno have it all wrong too.
This was in response to antenna height. Not sure how this is a counterpoint, therefore I'll take it as agreement regarding the height aspects and issues.kiltym wrote:Our customers are looking to get online
A typical marina setup (our company also installs marina Wi-Fi systems and are adding high rise buildings such as hotels, etc) uses high power antennas (typically outputing 4W EIRP). These antennas are installed high and point down onto the boats from above to give as clear a line of sight as possible to our users. Your laptops put out about 35-50mW. An adapter card that you get at a electronics box store puts out about 100mW. So you can hear the hotsot but it can't hear you back. Add to this that the antenna built into most laptops is built into the LCD cover. When you use it, it's usually tilted back at some angle thus not being perpendiclar to the hotspot. The hotspot is putting out the maximum power allowed by law (FCC Part 15.247), but with you sitting close to the waterline, trying to send your signal though a forest of metal with an antenna that's not usually aligned, you get a poorer connection. To get around this inequality as much as possible, we often install a generous number of access points around the property, but that adds considerably to cost and maintenance.kiltym wrote:All the marina's I have stayed at seem to know what they are doing then, as I can connect with my laptop alone.
We have units in use all over the world, even in Toronto! We have never had any issues with condensation in any of our units, nor will we. Our product was born down here in the Caribbean, but has been happy to migrate to places like Norway and Sweden too.I indicated that condensation requires a temperature change, something that does not really happen in the Caribbean.
I will refer back to my previous post, height can be the most important aspect of an install in very specific situations, but in most situations, additional height wont make any difference. Also, as you stated as well, most of the time people are within 1 mile of the access point, in which case the height at the top of your mast will definitely not be needed. Even up to 5 miles or so we have had customers connect, again, all mounted at about 6 ft off the deck of the boat.This was in response to antenna height. Not sure how this is a counterpoint, therefore I'll take it as agreement regarding the height aspects and issues.
