Page 3 of 3
tell me about it
Posted: Sun Jun 01, 2008 6:19 pm
by cmeperform
This is the way it came from the dealer.The atlanta
boating dealer.Wish I could have avoided them,But
I had a boat to trade in.They were close.They are
like fly's-LOL
by acdave
The line looks like a cheap nylon braid like the ones you find in plastic bag at Home Depot. They will never wind well. Try a yacht braid Sta-Set line from a marine supplier like West Marine. It will stay straight and lay in nice as you take in on the furler.
Posted: Sun Jun 01, 2008 9:40 pm
by MARK PASSMORE
trying to repost the pic of the rigging. not sure how to repost a pic from the thread.
by MARK PASSMORE
img][/img]
Craig, You dont need the extra block. That is the way Boating Atlanta had mine rigged. Just take it off because it gets tangled up. The Genoa sail needs to be attached to the line that runs though the block on the plastic sheath. I dont know why they rig the extra hailyard because you have one at the top of the mast for the main sail.
Posted: Sun Jun 01, 2008 9:42 pm
by Highlander
You have to run the line through your hands a few times & get all that twist out of that line or any other line you plan on using & then keep some tension on the line when unfurling to get a smooth rewind if you don't do this you will get the same problem regardless of what furling system you use , every time you coil a line you will put some twist into it I constantly run my lines to remove any twist in them " All lines "
The extra block is your jib halyard also used for your assy spin if you have one it is better to add an extra mast hound 9" or more above it and install it there if you have a spinn
Posted: Mon Jun 02, 2008 12:40 am
by c130king
And in your latest pic the line wrapped around your furler definitely looks like it was "loose" as it wrapped.
Make sure the small pulleys/blocks that lead your furler line from the furler to the cockpit are positioned such that the furling line is running into the furler drum at a "good" angle (going in near the middle of the furler and not rubbing against the top or bottom or against a support post)...
and keep tension on this line as the sail comes up so you get a nice tight wrap on the furler.
I think you can get that thing working.
Good luck,
P.S. Can you get Lyme Disease from eating a fish that was covered in ticks?
Thank you
Posted: Mon Jun 02, 2008 7:05 am
by cmeperform
Thanks for all the help.I will let all know when I get it fixed
Posted: Thu Jun 12, 2008 4:27 pm
by daydreamerbob
I am sure you fixed this by now. i have same furler from same dealer...and i put the mast raising system on the boat. disconected the forestay...and unscrewed those 4 phillips screws. then unwound the entire spool and rewrapped it. put the screws back together and was done...15 minutes tops.
but there was no turnbuckle under the spool?
And i do not know what the top of my furler looks like but if yours was wrong and mark's was wrong i assume mine is too?
Posted: Thu Jun 12, 2008 8:07 pm
by cmeperform
yes,I was headed out to sail around a little,as always , broke down again.batteries run dead this time.heck,I think this boat is a lemmon
Posted: Fri Jun 13, 2008 6:26 am
by cuisto
lets go guys, there lemonade a plenty to be had
Posted: Fri Jun 13, 2008 6:28 am
by Kelly Hanson East
The new Mac furler (late 2007 on) doesnt have a forestay turnbuckle anymore (the CDI turnbuckle is under the drum of course).
Per factory - "forestay tension is adjusted by adjusting the shrouds"
Posted: Fri Jun 13, 2008 6:43 am
by K9Kampers
Mark
(li'l buddy)-
Is this whut yer tryin' to do?
Don't worry, I'm still tryin' to figur how to make a multi-post quote!
HOW TO: Right click on the photo you want to re-post, select
Properties, highlight & copy the URL code. In your reply post, click the
Img button, Paste the code
(unaltered), click the
Img button again. Add text. Submit.
Posted: Sat Jun 14, 2008 5:48 am
by cmeperform
I'm still trying to figure all the out.Had some battery problems last
time I went out.Giving it another try soon.Thank you for helping.
