Mast Bearing Installed
Posted: Tue Sep 04, 2007 8:57 am
Base plate has a single thru bolt that is 9/16" bolt & nut and a single phillips screw. With the mast already down, it took me roughly 15 minutes to change out the washers and install the bearing assy (packed with white lithium grease. The mast rotates freely now. So much so that I had to tie it off when motoring in heavy waves to keep it from slapping back `n forth against the spreader.
Paul
Paul
