Replacement pelican hook on stock 26M lifeline
Post by Frank C »
mtc wrote:Apparently this is a common problem as my ring dings and pins have come out a couple of times. I'm planning on replacing them with p-hooks with retained pins so when the dings come out for what ever reason, the pins won't.
I surely would not spend 50 bucks for new P-hooks solely on this problem. The RD on mine is very stiff - no chance it would unwind itself.
Try replacing your RDs with a heavy duty SS key ring - that sucker'll stay put~! :wink:
Edit @ mtc - my P-hooks came with the heavy duty rings. Look on WM shelf, the ABI and Johnson brands have heavy rings. Ask salesman where you can find the those heavier rings.
Or - just browse at Hm Depot for a SS key ring.
mtc
Location: Panama City Beach, Florida 05 M 'Bellaroo' 60hp Merc BF
Post by mtc »
Frank,
That'll do the trick! These are the stock, verrrrryy thin RDs. Haven't seen thicker ones; where'd you get 'em?
Duane Dunn, Allegro
Post by Duane Dunn, Allegro »
My X had these added to the forward end of the cockpit lifelines by the PO. They are 'Sea Dog' brand and can be put in the stock adjusters with just a slight spreading of the metal. A simple ring ding pin holds them in place. I don't know where you can get them, but they work great.
Duane Dunn, Allegro wrote:I don't know where you can get them, but they work great.
Navy DOC
Pelican Hook received
Post by Navy DOC »
Just wanted to say a public thanks to everyone for their help and advice.
Thanks to Bill at BOATs 4 Sail, I now have a replacement pelican hook that I plan to install this weekend.
Thanks again.
-Mike
