Well, mine was a (hinged) bi-ducer for depth/temp, plus a uni-ducer for the paddle wheel, one mounted to each side of the outboard. In answer, Yes for the skimmer, but NO for the spinner, which has no hinges! Further, the kick-up skimmer would remain in the water, so both would still grow hair."Dimitri wrote:Frank, the bracket that the triducer is mounted with is already hinged and designed to kick up if it hits an obstruction. Unless yours is a different design, couldn't you just manually kick it up when you need to beach?
I guess I was thinking they might both mount on a single board, which could be attached to hinges above the waterline. Prolly more effort than reward.
